Dire Posted April 24, 2017 Posted April 24, 2017 (edited) So, this does not occur when cold start. After the engine is warm and i am poodling along e.g. 20 mph in 2nd or 30 in 3rd (revs between 2-3k cause anything lower and i get mega chatter from l.w flywheel..) if i hold the revs at a constant i get a tapping that gets louder the longer i hold it. As soon as i let off the throttle or increase the revs (even minutely), the tapping stops instantly. During testing... i could simulate this while in neutral and holding the revs between 2-3k also Anyone had this before? Might be worth noting i have a HR. But i cant seem to find this issue exactly with other cars either. Thanks. Edited April 24, 2017 by Dire Quote
Willsy1980 Posted April 24, 2017 Posted April 24, 2017 Possibly fuel damper, timing chain a little slack, one of the front belt pulleys or idlers heard the bearings in those do go sometimes or a rod bearing would be my guess, that may be louder than your knock. Those are the main knocky things. Whats the oil level like and how old is said oil ? Can you upload a video of the noise ? Quote
Miller350z Posted April 24, 2017 Posted April 24, 2017 I had a clicking/tapping noise on my car only a couple of weeks ago. Wouldn't do it as much in neutral just reving, but when under load accelerating from say 3rd gear from 20mph of 4th gear from day 30mph I got the noise. My exhaust y pipe was blowing but thought this couldn't be it as it sounds like it's coming from the rear..........got my y pipe changed and no more clicking/tapping. I even thought it could be detonation. I even put a video on YouTube "350z possible detonation" you have to turn it up load but you can just about hear it. I honestly wouldn't of thought they blowing y pipe would've been the cause of mine but it was. Sent from my SM-G930F using Tapatalk Quote
