Cold air intakes...
zippypooz
Here is my home-made version similar to an EVO-R performance cold intake duct.
It connects to the standard air-box containing a high flow AEM filter.
The intake entry sits flush behind the OEM grille occupying all the space normally taken up by the left hand plastic radiator shroud which I have removed.
The top seals against foam sheet on the normal OEM bulkhead air entry.
Inspiration came from the air intakes on high performance motorcycles, taking in air from a high pressure area at the front.
Fitted:
More pictures are needed for this! Looks a very neat way to guarantee a direct cold air flow!
  • 1 month later...
