350Z HR AAM Twin Turbo Kit - £11.5k
HaydnH
Hi All,
NOTE TO MODS: Apologies for not including photos, all the parts listed below are currently with Adrian@Torqen so I can't photo them. Adrian can confirm if needed. I hope that's OK?
As some of you are aware I've been waiting the buy for the AAM Twin Turbo kit as you'll find here:
http://www.350z-uk.com/topic/98901-torqen-torqen-partnerships-with-aam-to-develop-rhd-version-twinturbo-kit/
After 2 years all the parts have finally arrived and are waiting with Torqen for installation... unfortunately a mortgage has come along at the perfectly wrong time and I need to raise some money. All parts below are brand new, not even delivered to me yet, the kit includes:
- 350z HR AAM Twin Turbo Kit
- 350z Injector Dynamics 1000cc injectors, 48mm Length - 14mm Top - 14mm Lower O-Ring (Set of 6)
- 350z AEM In Tank Fuel Pump Kit Ethanol compatible 320 LPH
- GTM Fuel Return System
- 350z HR Clutch Masters FX300 Clutch Kit, Segmented Kevlar Steel Back System, 110% over stock holding capacity
- 350Z HR Clutch Masters Aluminum Flywheel, FW Weight: 13lbs
- 350z HR ZSP Tilton Racing Clutch Master Cylinder Upgrade
- 350z HR Mishimoto Oil Cooler Kit in black
- GReddy Profec Electronic Boost Controller
- Injector Dynamics injector harness plugs
- GT-R R35 spark plug
- 350z HR Stainless Steel clutch line
- Motul RBF 660 clutch fluid
- Fuchs Titan Pro Race S 5w30 engine oil 2 x 5L bottle
- Motul Inugel Coolant 1 x 5L bottle
- 350z Eibach Front and Rear Anti-Roll Sway Bar Kit
- 350z TWM Performance Short Throw Shifter
- 350z SPL PRO Front Endlinks
- 350z SPL PRO Rear Endlinks
The last 4 items are obviously not 100% required for a TT kit, if somebody wants to buy the TT kit without those 4 I'll knock £1k off, however I won't sell those 4 without selling the TT kit.
Regards,
Haydn.
EDIT: Just realised I missed the GTM fuel return system, added to the list with no price change.
Edited by HaydnH
...this needs to find a home!
So I can afford a home. :p
My justification in spending that much was a) what other car would perform as well as a TT'd Z for the same cash incl mods, comparible cars would cost much more and B) i love the Z. :)
I really wished I could justify spending the cars value on twin turboing it! Would be the ultimate machine! Good luck with the sale, this needs to find a home!
If only the finished price stopped at 11.5K LOL!!
Well this is everything you need to TT for £10.5k (less the £1k for the suspension bits), fitting would be about £3.5k at somewhere like H-Dev. Actually, you might need a little bit more depending on the exhaust you have, the downpipes from the kit are 3".
