Colin747 Posted April 10, 2017 Share Posted April 10, 2017 I recently got a new window switch unit fitted but I've noticed that when the door is opened it hits off the roof. It's fine when closing as the auto-lowering mechanism has lowered the window enough to close it no problem. Do I just need to take the door panel off to do the reset procedure or is this a different problem? Quote Link to comment Share on other sites More sharing options...
GT Driver Posted April 10, 2017 Share Posted April 10, 2017 Having the same problem here. Apparently there is a reset button on the window motor, that requires taking off the door card. However the reset procedure must be done with the door closed, and it's sort of hard to do that with the door card hanging down.. Quote Link to comment Share on other sites More sharing options...
veilside z Posted April 10, 2017 Share Posted April 10, 2017 Try the window switch reset buddy, worst thing is the panel coming off again. Quote Link to comment Share on other sites More sharing options...
