AdrianL Posted April 10, 2017 Share Posted April 10, 2017 Hi, So my clutch has started to slip, but it's a good opportunity to upgrade it. I've heard it's also worth doing the flywheel at the same time. I'm looking for a nice balance - I want the car to be comfortable on the road, but I do use it for some occasional track use too, so I'd like something that is good for both. A single mass, light flywheel seems appealing but if it's quite noisy this will be offputting. What clutch / flywheel combination is recommended? Thanks in advance, Adrian Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted April 10, 2017 Share Posted April 10, 2017 For road go for the setup in my tag. It only rattles a little at low revs and other than that is good quality and does the job very well It depends how much track you do I suppose but something for the track may not be ideal for gentler road use, which means it might be a bit rougher in 'normal' use? 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 10, 2017 Share Posted April 10, 2017 Hi Adrian, Have a look on this thread: http://www.350z-uk.com/topic/98182-torqen-350z-de-and-hr-clutch-kits-all-you-need-is-here/ Our most popular kit is the JWT combo, see here: https://www.torqen.uk/180-combo-packs Quote Link to comment Share on other sites More sharing options...
veeg33 Posted April 10, 2017 Share Posted April 10, 2017 Give traders here a call and discuss with them. Clarks Motorsport, Tarmac Sportz, Courgar Store etc etc (in no particular order)......they'll sort you out =) Quote Link to comment Share on other sites More sharing options...
AdrianL Posted April 10, 2017 Author Share Posted April 10, 2017 Hi Adrian, Have a look on this thread: http://www.350z-uk.c...u-need-is-here/ Our most popular kit is the JWT combo, see here: https://www.torqen.uk/180-combo-packs Cheers mate, what is the difference between these two please? https://www.torqen.uk/nissan/350z/powertrain/combo-packs/1895-350z-de-jwt-clutch-and-flywheel-combo-l3503-ncf-ktp-0x.html https://www.torqen.uk/nissan/350z/powertrain/combo-packs/664-350z-de-jim-wolf-technology-jwt-clutch-flywheel-kit-nodular-iron-26lb-flywheel-l3503-ncfsd.html Quote Link to comment Share on other sites More sharing options...
TT350 Posted April 10, 2017 Share Posted April 10, 2017 Torqen still doing biz from his villa in Florida Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 11, 2017 Share Posted April 11, 2017 Hi Adrian, Have a look on this thread: http://www.350z-uk.c...u-need-is-here/ Our most popular kit is the JWT combo, see here: https://www.torqen.uk/180-combo-packs Cheers mate, what is the difference between these two please? https://www.torqen.uk/nissan/350z/powertrain/combo-packs/1895-350z-de-jwt-clutch-and-flywheel-combo-l3503-ncf-ktp-0x.html https://www.torqen.uk/nissan/350z/powertrain/combo-packs/664-350z-de-jim-wolf-technology-jwt-clutch-flywheel-kit-nodular-iron-26lb-flywheel-l3503-ncfsd.html They use a standard pressure plate which is 900Kg compared to the 1200Kg clamping force. Quote Link to comment Share on other sites More sharing options...
AdrianL Posted April 11, 2017 Author Share Posted April 11, 2017 Which is the 900kg one and is that appropriate for 300bhp? Are they both SMF? Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted April 11, 2017 Share Posted April 11, 2017 This is our most popular kit for the DE Adrian, many happy owners on this forum. Its ideal for everyday use while still being suitable for using on track. In stock for next day delivery http://www.350z-uk.com/topic/95545-new-xtreme-clutch-organic-inc-smf-350z-de/ 1 Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 12, 2017 Share Posted April 12, 2017 (edited) Which is the 900kg one and is that appropriate for 300bhp? Are they both SMF? Yes, both SMF. 900kg is fine for 300bhp. 1200kg clamping force - https://www.torqen.uk/nissan/350z/powertrain/combo-packs/1895-350z-de-jwt-clutch-and-flywheel-combo-l3503-ncf-ktp-0x.html 900kg clamping force - https://www.torqen.uk/nissan/350z/powertrain/combo-packs/664-350z-de-jim-wolf-technology-jwt-clutch-flywheel-kit-nodular-iron-26lb-flywheel-l3503-ncfsd.html Edited April 12, 2017 by Adrian@TORQEN Quote Link to comment Share on other sites More sharing options...
davey_83 Posted April 12, 2017 Share Posted April 12, 2017 Why does the SMF result in extra noise at idle and low rpm, over the more complex DMF? Quote Link to comment Share on other sites More sharing options...
Tarmac@TarmacSportz Posted April 12, 2017 Share Posted April 12, 2017 Stock kits here if you want it like it came out the factory http://www.350z-uk.com/topic/114962-350z-de-oem-replacement-clutchfly-ancillaries-packages-565/ Or The next best option is Xtreme as Ewen says https://www.tarmacsportz.co.uk/nissan-350z-03-06-vq35de-xtreme-clutch-kits.html I currently have a 350z with JWT and its gash getting it into 2nd, don't know why as it was fitted on the car when I got it but it hadn't done many miles 1 Quote Link to comment Share on other sites More sharing options...
Ewen@Clark Motorsport Posted April 12, 2017 Share Posted April 12, 2017 Why does the SMF result in extra noise at idle and low rpm, over the more complex DMF? The dual mass flywheel is designed to dampen the extra noise so removing that is why you do get an increase. The Xtreme kits flywheel is optimised for weight to try and minimise this noise. The overall benefits far outweigh the noise 2 Quote Link to comment Share on other sites More sharing options...
mr v6 Posted April 12, 2017 Share Posted April 12, 2017 Previous owner of my Z had this stage 1 kit & SMF conversion from Clark Motorsport early last year, I'm assuming it's the same flywheel as in Ewan' post? The pedal is never going to be super light, it's firm, but a comfortable firm. Can feel a little grabby at times & will never be as silky smooth as a DMF & standard clutch. Quote Link to comment Share on other sites More sharing options...
Carbon.Ninja Posted June 4, 2017 Share Posted June 4, 2017 I recently opted for the ORC 409 Metal Series clutch for mine. Comes with flywheel and the throw out bearing. Didn't have enough time so I didn't opt for the quiet special order option. They are all damped and high Mu disc for 350z. Sent from my Nexus 6 using Tapatalk Quote Link to comment Share on other sites More sharing options...
