Tom S 350z Posted April 8, 2017 Share Posted April 8, 2017 Hi I'm new but I need your advice before I loose my mind with my 350z So my car flicked on the engine management light and then began to loose power and kangaroo like it was dying and coning back to life, then the ESP light and traction control light came on! So I did my checks and research and changed the coil packs, plugs, crank sensor and both cam sensors and it went away for a bit. Then it came back so I decided to change the chain! Chain changed and found that the timing was out by a tooth and thought this must be it!! ITS NOT!! After a day of it driving perfect it has now come back and is playing up more than ever now!! Engine lights on, ESP is on and traction control light is on its hard to start and when it finally fires up it keeps loosing power and dying! I can't win on my own with this one so I ask for all your knowledge and 350z guruness to help me fix this annoying money pit Quote Link to comment Share on other sites More sharing options...
coldel Posted April 8, 2017 Share Posted April 8, 2017 Did you not get a report code from the car? Usually that will tell you the issue? Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 8, 2017 Author Share Posted April 8, 2017 I'm going to hook it back up tomorrow and see what it brings up, every time iv done it it brings up the code for cam and crank senor faults Quote Link to comment Share on other sites More sharing options...
coldel Posted April 8, 2017 Share Posted April 8, 2017 OK good, post up as much info on codes, reports etc and the guys will give an opinion. Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 8, 2017 Author Share Posted April 8, 2017 Thank you mate I will do! I just can't get my head around it iv changed so much related to the issue I can't think of anything else it would be Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 8, 2017 Share Posted April 8, 2017 A word to the wise, after market new sensors do not work so got to be genuine Nissan. Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 8, 2017 Author Share Posted April 8, 2017 Yeah they are genuine Nissan sensor Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 8, 2017 Share Posted April 8, 2017 Okay, as been said, post up the DTCs. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 8, 2017 Share Posted April 8, 2017 (edited) And the model and year of your car. Edited April 8, 2017 by ZMANALEX Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 8, 2017 Author Share Posted April 8, 2017 Will do guys thanks Quote Link to comment Share on other sites More sharing options...
KyleR Posted April 8, 2017 Share Posted April 8, 2017 Bring it to the Cougar Store, they know the 350 inside out. Quote Link to comment Share on other sites More sharing options...
Erni902 Posted April 8, 2017 Share Posted April 8, 2017 I have a similar kind of problem with mine although I get no lights etc. It throws up codes for various sensors but after swapping all of these no change. I too changed the chain but again no change and same codes. My next port of call is getting the flywheel checked for misalignment. Has yours had a clutch/flywheel change recently? Quote Link to comment Share on other sites More sharing options...
Dundee Z Posted April 8, 2017 Share Posted April 8, 2017 I am having similar issues to this and started a different thread. Here's the codes i have been getting Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 9, 2017 Author Share Posted April 9, 2017 I have a similar kind of problem with mine although I get no lights etc. It throws up codes for various sensors but after swapping all of these no change. I too changed the chain but again no change and same codes. My next port of call is getting the flywheel checked for misalignment. Has yours had a clutch/flywheel change recently? Quote Link to comment Share on other sites More sharing options...
Tom S 350z Posted April 9, 2017 Author Share Posted April 9, 2017 Nope I haven't had the fly wheel or clutch change although the clutch is a little high but it's not slipping Quote Link to comment Share on other sites More sharing options...
