350z project, now done...almost (pic heavy)
zxrjohn14
As a few of you know, i was after a 350z project and bought a nice example from eBay for £2150 delivered to my door.
It was a crashed, Cat C car and a JDM import.
I am waiting for the guy i bought it from to send me the pictures, as stupidly, i was that excited i never took any pictures of it with all the broken bodywork on
Anyway....this is it mid strip
The damage was:
Wing
bumper
wheel
wheel assembly
nudge bar
headlight
radiator surround
wheel liner
headlight frame
for fun, i fitted:
leather interior and built my own loom for the heat and electrics
fitted a full Bose system (i think it's awesome!!)
fitted a UK pod for MPH and MPG
fitted a USB charger
carbon wrapped the centre console
wheel before
wheel after
i bought a 20" damaged wheel from Shpock for a fiver, cut a good piece out to the shape and size required, cut the damage out of the original the same shape and TIG welded away!!
this was a project to keep my mind occupied and have somethink nice to play with once done. I normally build motorbikes to occupy my mind but a 350z is an itch that needed scratching since they come out.
i've done all the work on this myself, including the spraying, which i think, has come out remarkably well for doing it in the shed
Today i took it for an MOT and it passed, i am so happy :teeth:
i'd like to say a massive thank you to Jon at Emporer for his help advice and supplying some of the bits for my build
the things left to do are:
wheel refurb
make the sill skirt up where its broken
excuse the halo effect on some of the pictures, this is because i dropped my phone and cracked all of the glass around the camera lens
Edited by zxrjohn14
  • Like 7
Thank you all.
It arrived 13th February and I've been working on it most weekends, some evenings and a few days off work here and there.
I've checked all of the car over to make sure everything is ok on it.
It does seem to be a very well looked after car and has benefited from a recent service by the looks of it.
How did you go about fitting the USB charging point ?
Hats off to you for all the work you've done! Pretty inspiring stuff! Glad she didn't end up at some scrap yard and fell into your lucky hands instead 🤓
The charger is from a Toyota and is a similar shape. I removed the plastic from the switch housing just leaving the clip tangs and put a small cable tie around the tangs. The hooks are just in the right place to hold the bottom of the switch and hold it nice and tight against the top, the wiring got put to a switched live on the stereo.
:D i may have a go. I'm quite a "right let's do this sh!t" kinda guy, but am always willing to help.
If anyone ever wants any help in my area (Bourne, Lincolnshire), i can always assist and lend my small bit of knowledge and hands.
Edited by zxrjohn14
🤔you might regret saying that 😂😂
I am in Peterborough so not too far away...
Sent from my iPhone using a hammer and chisel
