Paul_B Posted April 7, 2017 Share Posted April 7, 2017 Hi everyone I was fitting my airbox mod this evening and relised that my throttle body was covered In what I can only assume as carbon. Is this normal? Would a catch can help? Thanks Quote Link to comment Share on other sites More sharing options...
davey_83 Posted April 7, 2017 Share Posted April 7, 2017 Clean it out, the butterfly goes in at the top so if you push on top from behind it wont move when cleaning. However to clean properly you will need to move the butterfly. Quote Link to comment Share on other sites More sharing options...
Toon Chris Posted April 8, 2017 Share Posted April 8, 2017 (edited) To add to this ^ make sure the ignition is off and you need to use a spray of carb cleaner for best results. And yes, it is normal. Edited April 8, 2017 by Toon Chris Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted April 8, 2017 Share Posted April 8, 2017 As above, plus best to disconnect multi plug, battery and ECU before you move the butterfly. Quote Link to comment Share on other sites More sharing options...
Paul_B Posted April 8, 2017 Author Share Posted April 8, 2017 Thanks everyone Quote Link to comment Share on other sites More sharing options...
