scotzman Posted April 6, 2017 Author Share Posted April 6, 2017 Never noticed them reading differently or otherwise, the speedo could be a MPH sticker i guess but digital was def kph Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted April 6, 2017 Share Posted April 6, 2017 I think your missing the point, the digital gauge will always have the letters, kmh, regardless of a speed chip. So, presumably your speedo registers the speed your travelling in mph and the digital gauge shows roughly the same speed? Quote Link to comment Share on other sites More sharing options...
scotzman Posted April 6, 2017 Author Share Posted April 6, 2017 I think you're right, the only JDM cluster with MPH that I can find after a fairly extensive search, is the Nismo article for 800 quid from Japan. therefore, I would agree that if he has a facia that shows mph and digi that shows kph, there must be a converter (and a change of facia) in the mix. If you can stomach that price, scotzman, that's the one to get!! Here's a second hand one for a little less. http://www.ebay.co.uk/itm/252443327434 Or just get my speedo fixed Quote Link to comment Share on other sites More sharing options...
scotzman Posted April 6, 2017 Author Share Posted April 6, 2017 I think your missing the point, the digital gauge will always have the letters, kmh, regardless of a speed chip. So, presumably your speedo registers the speed your travelling in mph and the digital gauge shows roughly the same speed? Thats what i would have thought Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted April 7, 2017 Share Posted April 7, 2017 http://www.sumopower.com/product/sumo-power-speedo-converter--delimiter-cartek-ck-un-09 Ok, so if you registering in mph, you most likely have one of the above, which is what i have had problems in the past with, along with a few others. It will most likely be spliced into the loom behind the instrument cluster, so remove the cluster, there is a guide in here somewhere and its pretty easy, you will be left with the instrument multi pin connecter sticking out the dash and hopefully you should see one of these spliced into the loom. Remove and re connect the original colour coded loom wires, reinstall instrument cluster and see that your speedo works. Put some photos up if your unsure. Quote Link to comment Share on other sites More sharing options...
scotzman Posted April 7, 2017 Author Share Posted April 7, 2017 http://www.sumopower...cartek-ck-un-09 Ok, so if you registering in mph, you most likely have one of the above, which is what i have had problems in the past with, along with a few others. It will most likely be spliced into the loom behind the instrument cluster, so remove the cluster, there is a guide in here somewhere and its pretty easy, you will be left with the instrument multi pin connecter sticking out the dash and hopefully you should see one of these spliced into the loom. Remove and re connect the original colour coded loom wires, reinstall instrument cluster and see that your speedo works. Put some photos up if your unsure. Jet if i remember right when had it facia and cluster out to do the cameras, i always check pin connections before i put anything back and it looked like there was no connections added to the cluster loom, but will remove it today to double check and will post a couple of pics. Quote Link to comment Share on other sites More sharing options...
scotzman Posted April 17, 2017 Author Share Posted April 17, 2017 Only thing connected is the "speed limit fencer" as in pic in post #9 Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted April 17, 2017 Share Posted April 17, 2017 Well that would be my first step, disconnect and see if your speedo works. Quote Link to comment Share on other sites More sharing options...
scotzman Posted April 18, 2017 Author Share Posted April 18, 2017 Well that would be my first step, disconnect and see if your speedo works. Would i have to reconnect the original wires obviously Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted April 19, 2017 Share Posted April 19, 2017 I am not that familiar with the speed cut thingy, but presume it splices into the loom? If so just remove and reconnect the origìnal wires. Quote Link to comment Share on other sites More sharing options...
PEDROKAT Posted May 1, 2017 Share Posted May 1, 2017 Did you ever resolve this? I'm fighting a similar problem....swapped speedo... no different....swapped sensors on diff. ..and checked fuses.... still no good.... thinking of pushing it in the sea. .. Peter Quote Link to comment Share on other sites More sharing options...
scotzman Posted May 1, 2017 Author Share Posted May 1, 2017 Did you ever resolve this? I'm fighting a similar problem....swapped speedo... no different....swapped sensors on diff. ..and checked fuses.... still no good.... thinking of pushing it in the sea. .. Peter Hi Peter, was told its possibly the speed sensor on the gearbox, so im gonna PM Jon@emperor and see if he has one... worth a try Quote Link to comment Share on other sites More sharing options...
