Mavrik Posted April 4, 2017 Share Posted April 4, 2017 I'm a noob on here Just bought a Scorpion Y section back & am attempting to install it myself (took it to 3 garages locally but unable to get it on their ramps due to having been lowered with Vogtland springs!!) How the fook do you easily remove the rubber support bung that's above the rear silencer?? Should I remove the actual bracket from the chassis? Got it on axle stands so very limited clearance still Quote Link to comment Share on other sites More sharing options...
Mavrik Posted April 5, 2017 Author Share Posted April 5, 2017 Doh!! All done... Good old WD40 :-P Is decibel pornage ... Quote Link to comment Share on other sites More sharing options...
Bullet Posted April 5, 2017 Share Posted April 5, 2017 I hope you used genuine gaskets on the cat to Y joints as the ones supplied with the exhaust burn through in a couple of weeks. Quote Link to comment Share on other sites More sharing options...
Mavrik Posted April 9, 2017 Author Share Posted April 9, 2017 I hope you used genuine gaskets on the cat to Y joints as the ones supplied with the exhaust burn through in a couple of weeks. I didn't get any gasket with the Scorpion I re-used the original gasket which seemed in decent usable condition (I have always used copperslip to join exhausts with zero issues) ... We'll see if it leaks Quote Link to comment Share on other sites More sharing options...
