S7nny Posted April 2, 2017 Share Posted April 2, 2017 So I'm looking for a fabricator/body shop near Windsor/Slough/Reading (willing to travel within reason) that can fit a 370 rear bumper into a 350. Go! Quote Link to comment Share on other sites More sharing options...
Wasso Posted April 2, 2017 Share Posted April 2, 2017 (edited) TGM in Fleet. That is gonna be a very expensive modification! Edited April 2, 2017 by Wasso 2 Quote Link to comment Share on other sites More sharing options...
Payco Posted April 2, 2017 Share Posted April 2, 2017 As above or RT Performance Wembley but as Ian says it will need a lot of fabricating. 1 Quote Link to comment Share on other sites More sharing options...
veilside z Posted April 3, 2017 Share Posted April 3, 2017 Lights front wings and bonnet too. Its already been done. Quote Link to comment Share on other sites More sharing options...
ilogikal1 Posted April 3, 2017 Share Posted April 3, 2017 Lights front wings and bonnet too. Its already been done. That IS a lot of fabrication to make it fit the front wings.... Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted April 3, 2017 Share Posted April 3, 2017 (edited) ^^^ except he is asking about a rear bumper fit not meant for you Ilokigal Edited April 3, 2017 by Jetpilot Quote Link to comment Share on other sites More sharing options...
jumping350 Posted April 3, 2017 Share Posted April 3, 2017 Can be done though Quote Link to comment Share on other sites More sharing options...
Adrian@TORQEN Posted April 3, 2017 Share Posted April 3, 2017 RT-Performance has my 370z bumpers there in case you need it Quote Link to comment Share on other sites More sharing options...
ShortPaul Posted April 4, 2017 Share Posted April 4, 2017 Why not by a 370í ½í¸ Quote Link to comment Share on other sites More sharing options...
Luke0549 Posted April 4, 2017 Share Posted April 4, 2017 Personally i think it will look gash. 1 Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted April 4, 2017 Share Posted April 4, 2017 I'm gonna bite, and ask...why? What bumper are you trying to fit? I hope it's not the Amuse (AMS GT), because there is already A 350Z version available to buy, it'll still need some fabrication (, don't they all?), but it won't half be easier to fit!! Quote Link to comment Share on other sites More sharing options...
S7nny Posted April 5, 2017 Author Share Posted April 5, 2017 I'm in love with the Varis V2 370 rear - that's why! I don't fancy a 370 over the 350 I already have. It's a preference! Quote Link to comment Share on other sites More sharing options...
Davectr Posted April 5, 2017 Share Posted April 5, 2017 Good for you S7nny, everybody has different tastes and if that's what you want to do to your Zed go for it. It may be difficult to find someone to do it, but someone will. It'll be a big task, and therefore likely to be costly but it will be unique í ½í±í ¼í¿» 1 Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted April 5, 2017 Share Posted April 5, 2017 (edited) Not for me personally, but it is quite agressive looking. image courtesy of Bulletproof automotive The closest one I've seen to that for the 350Z is this one (link below). I'm sure it would be cheaper and look better in the end to have a fabricator cut or mould the vents to this, rather than trying to make a 370 item fit the 350...use your imagination and you should be able to get quite close to the Varis... http://www.madmotors...ear-bumper.html Edited April 5, 2017 by Aashenfox Quote Link to comment Share on other sites More sharing options...
S7nny Posted April 5, 2017 Author Share Posted April 5, 2017 It seems to be some way off from the finished article; but I appreciate the recommendation, regardless. I am a fan of the aggressive looking kits. I think it would finish off the rocket bunny kit quite nicely instead of the stock bumper. This is definitely something I need to look at and press on with! Not for me personally, but it is quite agressive looking. image courtesy of Bulletproof automotive The closest one I've seen to that for the 350Z is this one (link below). I'm sure it would be cheaper and look better in the end to have a fabricator cut or mould the vents to this, rather than trying to make a 370 item fit the 350...use your imagination and you should be able to get quite close to the Varis... http://www.madmotors...ear-bumper.html Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted April 5, 2017 Share Posted April 5, 2017 As the other member said, fair play to you for having a clear idea what you want and going after it. I wish you the best of luck getting a result you are happy with. 1 Quote Link to comment Share on other sites More sharing options...
jumping350 Posted April 5, 2017 Share Posted April 5, 2017 (edited) having done similar and played around with it, first problem is 370z bumper is wider, second is exhaust tail pipe holes will be jacked out of line if you cut bumper to size, the way I did it was cut relevant sections out of 370z bumper cut sections out of 350z bumper and bonded/rivoted/smoothed them together that way I still had oem fitment with look i wanted. However doing it this way will leave a 370z exhaust gap with a 350z exhaust, simple thing I did was cut and reweld tips to suit Thats my 2 cents anyway Edited April 5, 2017 by jumping350 1 Quote Link to comment Share on other sites More sharing options...
