Installing a xtron head unit
Nikster
Hi, I'll ve picking up a z this week and wondering whats I need to connect my xtrons double din fit and work with everything. I have a xtrons td618 from my lexus is200. I know I'll need a fitting kit and stuff but cab anyway advise ne exactly what one and what else I'll need?
Thanks
Do you the bose system? Ive just done mine and what I needed d was...
https://incartec.co.uk/Pages/Product.aspx?P=2975
This is the main harness, you'll need to swap the red and yellow wire so the unit gets power correctly, the remaining blue wire on the harness is your antenna power so I cut that and linked it to the xtrons directly
https://incartec.co.uk/Pages/Product.aspx?P=2651
This plugs into the steering box on the above harness and links to key1 and key2 on your xtrons
Incartech do a kit with the facia as well but I found it far far too tight so im ordering from elsewhere
After that I also had to modify my harness to turn the phono connections into an iso one, this is called the buster mod on the forums, just be aware your taking speaker outputs and connecting them to your amp,the volume levels will be louder!
I've seen on ebay some rca to iso blocks if your not confident with your soldering
Good luck its easy to do but lack of a specific guide did make it confusing so hopefully you'll find the above answers everything!
