LDUNKZ18 Posted March 31, 2017 Share Posted March 31, 2017 Ok so currently fitting new clutch and flywheel.. just curious as to the thrust bearing is there meant to be a clip for it like the oem thrust bearing? Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 31, 2017 Share Posted March 31, 2017 Not 100% sure on your particular one but my thought is yes - you may find you actually use the clip from the OEM - I have seen that before Quote Link to comment Share on other sites More sharing options...
huseyin Posted April 1, 2017 Share Posted April 1, 2017 Yeah you use the old one thats what i did with mine when i fitted my xtreme clutch kit Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted April 1, 2017 Author Share Posted April 1, 2017 Clutch is fitted. Having issues bleeding it now though. Any tips Quote Link to comment Share on other sites More sharing options...
huseyin Posted April 1, 2017 Share Posted April 1, 2017 Honestly i hope you do not go through what i did . My car was in the garage for 2 weeks wont go into gear . I changed the slave cylinder , braided clutch lines even upgraded the master cylinder to a willwood one . Bleeding it is really important and quite tricky there is a lot of air trapped in it there should be a guide somewhere on here i would try to find it Quote Link to comment Share on other sites More sharing options...
huseyin Posted April 1, 2017 Share Posted April 1, 2017 Here http://www.350z-uk.com/topic/78790-350z-clutch-masterslave-issues/ Quote Link to comment Share on other sites More sharing options...
LDUNKZ18 Posted April 1, 2017 Author Share Posted April 1, 2017 All sorted. Bled itself Over night jamp in today and had a pedal again and got gears. Happy days! 1 Quote Link to comment Share on other sites More sharing options...
