TiN TiN Posted March 28, 2017 Posted March 28, 2017 Has anyone played around with the stock set up and got a decent fast road set up with toe adjustments? If so, what specs have you used? What level of toe has been used on front and rear? Any drift specs out there? What's recommended? Quote
RobPhoboS Posted March 28, 2017 Posted March 28, 2017 There isn't much you can do stock.. so you need to spend money in order to get any specific settings. However...you can obviously drift without doing anything to the car. Quote
TiN TiN Posted March 28, 2017 Author Posted March 28, 2017 Do people just use the standard Nissan spec on the stock Z's? I would have thought more toe out on the front, and more toe in on the rear would decrease understeering? There must be someone who's tested alignment settings on a stock Z! Quote
ZMANALEX Posted March 28, 2017 Posted March 28, 2017 Most have played around with the settings, however it is a personal choice based on what you are trying to achieve. There is ample toe adjustment on the front and plenty on the rear if you are not lowered. Start at stock settings and tweak as required to suit your driving style. I could give you my settings, however these probably would not suit your car or your driving style. Quote
TiN TiN Posted March 28, 2017 Author Posted March 28, 2017 I want the car to understeer less, and oversteer more. Fast road/drifty spec. Anyone got any settings I could test out? Quote
davey_83 Posted March 28, 2017 Posted March 28, 2017 You can influence understeer/oversteer with tyre pressures for track sessions 1 Quote
brillomaster Posted March 28, 2017 Posted March 28, 2017 maybe run a square setup? you could put a 245/40/R18 on the front, which would keep a 3.6% difference to the rears so should keep the tcs happy. or alternatively a thicker rear anti roll bar would increase oversteer. Quote
RobPhoboS Posted March 28, 2017 Posted March 28, 2017 (edited) Either way, aside from tyre pressure - it involves money, and as I said you can't adjust the camber on stock sadly. I'm not sure he quite understands our stock setup (not intending to be rude btw!!!). If he wants specific settings = adjustable camber arms front and rear and arb's etc Edited March 28, 2017 by RobPhoboS Quote
ZMANALEX Posted March 28, 2017 Posted March 28, 2017 Either way, aside from tyre pressure - it involves money, and as I said you can't adjust the camber on stock sadly. I'm not sure he quite understands our stock setup (not intending to be rude btw!!!). If he wants specific settings = adjustable camber arms front and rear and arb's etc The OP is only asking for toe settings: Quote
RobPhoboS Posted March 28, 2017 Posted March 28, 2017 Either way, aside from tyre pressure - it involves money, and as I said you can't adjust the camber on stock sadly. I'm not sure he quite understands our stock setup (not intending to be rude btw!!!). If he wants specific settings = adjustable camber arms front and rear and arb's etc The OP is only asking for toe settings: True true but some camber would be good. (esp over stock) Quote
TiN TiN Posted March 28, 2017 Author Posted March 28, 2017 Yeah. I don't have adjustable camber arms anymore, so just looking for toe settings.. I'm just going to use Nissan's recommended settings but be at the boundaries of toe out at the front and toe in on the rear. Thanks for the feedback anyway guys Sent from my E6653 using Tapatalk Quote
