scobie140 Posted March 28, 2017 Share Posted March 28, 2017 I can't find any pics of a zed with the intercooler fitted that has the two washer bottles. I've just fitted my pipework last night but it just doesn't seem right. Don't get me wrong it all fits but i'm concerned its going to stick out a bit. Has any of you boosted guys got the two bottles and can shed any light on this? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted March 28, 2017 Share Posted March 28, 2017 Fitting smaller bottles is the way that most go. I actually did away with the headlamp washer bottle. Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 28, 2017 Share Posted March 28, 2017 When mine was fitted I did have the headlight washer bottle completely removed but in hindsight we realised you can either use a smaller bottle as Alex suggest or re-route the pipe work so it pulls the washer fluid from the same bottle as your windscreen washer fluid. Quote Link to comment Share on other sites More sharing options...
scobie140 Posted March 28, 2017 Author Share Posted March 28, 2017 Bummer! Is there a specific bottle to replace it with or just a generic universal one? Might have a look and see if looks easy enough just to re route the pipes. Knew things were going to smoothly Sent from my SM-G900F using Tapatalk Quote Link to comment Share on other sites More sharing options...
GMballistic Posted March 28, 2017 Share Posted March 28, 2017 Bummer! Is there a specific bottle to replace it with or just a generic universal one? Might have a look and see if looks easy enough just to re route the pipes. Knew things were going to smoothly Hopefully Alex will come back with some more info on that for you. I did find these 1.2L and 1.8L bottles from Torqen when I searched. Link: https://www.torqen.uk/nissan/350z/body-styling/exterior/2804-windshield-washer-bottle-replacement-kit-1040010402.html The windscreen washer bottle is big enough though to supply both windscreen & headlight washers. I think it might have been Sam Mcgoo who told me about re-routing the pipes to the one bottle after I was complaining that I didn't have a headlight washer bottle anymore after supercharging. After all both pumps are already on the one bottle anyway. Quote Link to comment Share on other sites More sharing options...
scobie140 Posted March 28, 2017 Author Share Posted March 28, 2017 Bummer! Is there a specific bottle to replace it with or just a generic universal one? Might have a look and see if looks easy enough just to re route the pipes. Knew things were going to smoothly Hopefully Alex will come back with some more info on that for you. I did find these 1.2L and 1.8L bottles from Torqen when I searched. Link: https://www.torqen.u...1040010402.html The windscreen washer bottle is big enough though to supply both windscreen & headlight washers. I think it might have been Sam Mcgoo who told me about re-routing the pipes to the one bottle after I was complaining that I didn't have a headlight washer bottle anymore after supercharging. After all both pumps are already on the one bottle anyway. Yeh hope he can chip in with an easy fix as i'm just after what ever is going to be the easiest solution. Cheers I've not had a chance to look I've been trying to make the most of the last bit of dry weather, I'll have a look see if there are any more that are plug and play as I've no idea what the fittings are called that are on the washer system. I had a quick look at the piping set up but didn't want to waste too much time since I've still got loads left to get on with so couldn't figure out how to run off the one bottle. Quote Link to comment Share on other sites More sharing options...
Elliot350 Posted April 6, 2017 Share Posted April 6, 2017 (edited) http://www.350z-uk.com/topic/66319-inevitable-going-the-fi-way-now-done-update-13052013/page__st__280#entry1044113 Look here I believe the 8th picture down in part 1 is what you're after. Simply loop one side in to the other where the two pipes would normally shoot off to the opposite side of the car to the other bottle. Edited April 6, 2017 by Elliot350 Quote Link to comment Share on other sites More sharing options...
Stutopia Posted April 6, 2017 Share Posted April 6, 2017 Kill the headlight washers and never soak your bonnet again Quote Link to comment Share on other sites More sharing options...
