one tail light not working?
GeorgeW
So I have had my new Z for a week now. '06 with Veilside kit. Bodywork is in good condition and only a few common Z problems came with it, which I have already fixed. However today I noticed one of the rear brake lights don't work. These are custom LED lights so can't be a duff bulb issue, what else could be causing it?
These are the lights if it helps paint the picture better.
Excuse the wheels - some proper ones are on order!
Edited by GeorgeW
Just to close the chapter, I took the rear light out today and cleaned the contacts, put it back together and works 100%. Either needed a clean or he may have got the connections the wrong way around, either way it works!
  • 3 weeks later...
  • 1 month later...
Guys I still need to get to the bottom of this! So to bring you up to date:
I sold my LED lights and put on an OEM set.
The right hand side doesn't seem to work at all - e.g. Normal light or brake light.
I found the ground point on the rear of the boot, took it off and cleaned it, but still nothing.
If I disconnect the left hand tail light, the right one magically works.
I have found where the tail light relay should be next to the battery - but there isn't one - maybe something to do with it?
Any help would be great!
