Help needed - Lexus alarm freeze
H5
Kick it??
Seriously though, could it be the keyfob that's gone? Got a spare keyfob you could try or has the sensor in-car gone? My Clifford sometimes played up and I had to put the fob right next to the receiver for it to work in dodgy signal areas.
open bonnet
pick up hammer
hit three times, careful you must time the hits with precision timing. They need to be two seconds apart.
Close bonnet :teeth:
if the led light is still flashing, you will need to repeat the above procedure
open bonnet
pick up hammer
Tried that....
Didn't work. What next?? :teeth:
disconnect battery for a few mins
Not a bad idea. Lexus reckon it might be that the key barrel thinks the key is still in - battery might reset that?
give it a try , It cant harm it ;)
At least not anymore than I can! :rant::lol:
