Engine cut out while driving, can't start engine, no fault codes!
Rob T
On the way to work today my engine suddenly stalled when I was changing from 2nd to 3rd gear at approx 5500rpm.
While still rolling I managed to get it started again, but immediately it cut out when I tried to put it in gear.
I then pulled over and the car would not start properly. When you turn the key, it catches, but then just cuts out straight away.
My mechanic has seen it, and guesses it may be the air flow sensor, but there are no fault codes, other than an O2 sensor code due to the decats.
I've only had the car for a week, and it's been a nightmare!!
Nothing else happening? battery OK alarm/remote locks and unlocks the car fine?
Check for a good engine earth as well, I had that problem but it would not start at all.
Hmm sounds to me like either crankshaft sensor or an immobiliser fault however you should see a fault code for crankshaft sensor.Fuel pump?.Can you still hear it prime up?.
I didn't get an error for the cam sensor - however I knew it was that as I'd just changed it over.
didn't happen again after putting the original one back in.
