Rob T Posted March 20, 2017 Share Posted March 20, 2017 On the way to work today my engine suddenly stalled when I was changing from 2nd to 3rd gear at approx 5500rpm. While still rolling I managed to get it started again, but immediately it cut out when I tried to put it in gear. I then pulled over and the car would not start properly. When you turn the key, it catches, but then just cuts out straight away. My mechanic has seen it, and guesses it may be the air flow sensor, but there are no fault codes, other than an O2 sensor code due to the decats. I've only had the car for a week, and it's been a nightmare!! Quote Link to comment Share on other sites More sharing options...
Keyser Posted March 20, 2017 Share Posted March 20, 2017 Nothing else happening? battery OK alarm/remote locks and unlocks the car fine? Check for a good engine earth as well, I had that problem but it would not start at all. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 20, 2017 Share Posted March 20, 2017 Cam position sensor or maybe crank position sensor are possibilities. (note - if you do try them, dont use a cheap ebay one!) Quote Link to comment Share on other sites More sharing options...
Rob T Posted March 20, 2017 Author Share Posted March 20, 2017 No, other than what I've said, there are no other noticeable problems. Quote Link to comment Share on other sites More sharing options...
Gassy Posted March 20, 2017 Share Posted March 20, 2017 Hmm sounds to me like either crankshaft sensor or an immobiliser fault however you should see a fault code for crankshaft sensor.Fuel pump?.Can you still hear it prime up?. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted March 20, 2017 Share Posted March 20, 2017 Hmm sounds to me like either crankshaft sensor or an immobiliser fault however you should see a fault code for crankshaft sensor.Fuel pump?.Can you still hear it prime up?. I didn't get an error for the cam sensor - however I knew it was that as I'd just changed it over. didn't happen again after putting the original one back in. Quote Link to comment Share on other sites More sharing options...
Jay84 Posted March 20, 2017 Share Posted March 20, 2017 It could be something simple like spark plugs going down. Quote Link to comment Share on other sites More sharing options...
docwra Posted March 20, 2017 Share Posted March 20, 2017 Can you hear the fuel pump priming? AFM issue may not give a fault code so it could be that but it should still start and run on limphome rather than die entirely, my money is on fueling somewhere. Quote Link to comment Share on other sites More sharing options...
Rob T Posted March 20, 2017 Author Share Posted March 20, 2017 (edited) Spark plugs were replaced in July, so shouldn't be that. Edited March 21, 2017 by Rob T Quote Link to comment Share on other sites More sharing options...
Rob T Posted March 20, 2017 Author Share Posted March 20, 2017 Thanks for the info so far. I'm getting it recovered to my mechanic's tonight. Hopefully have more info for you tomorrow. Quote Link to comment Share on other sites More sharing options...
Rob T Posted March 21, 2017 Author Share Posted March 21, 2017 (edited) Fuel pump is priming, so not that either. Edited March 21, 2017 by Rob T Quote Link to comment Share on other sites More sharing options...
davey_83 Posted March 21, 2017 Share Posted March 21, 2017 Any updates? Quote Link to comment Share on other sites More sharing options...
Ebized Posted March 21, 2017 Share Posted March 21, 2017 Maybe not in this case but having read many similar threads on here, and when feedback does pop up, the battery/earthing has quite often been reported as the problem. Quote Link to comment Share on other sites More sharing options...
Jez @ H-Dev Posted March 21, 2017 Share Posted March 21, 2017 As above: Cam/crank sensor most likely - and use genuine. The non-genuines often don't work when brand new. Quote Link to comment Share on other sites More sharing options...
Rob T Posted March 22, 2017 Author Share Posted March 22, 2017 Swapping the MAF sensor seems to have solved the problem! The car is running well now, but I will be keeping a close eye on it. Many thanks for all the replies 👌 3 Quote Link to comment Share on other sites More sharing options...
