Satilite dish
snoged
Hi all anyone know which dish i should buy ?
I have been using Freesat and quite happy with this , but all has recently stopped working ,so rather than try and sort out which bit has packed up.thought i would replace the lot,and this time run the cables internally and not throw them across the roof .
Any advice will be much appreciated.
Thanks !
Is the tuner in the TV working correctly, IE does it just report no signal or another fault? what TV is it? all kind of depends what you want, my TV has built in satellite positioner as well so i have a larger motorised dish, but if you just have free-sat then you just need a small fixed dish and universal LNB, which you can ger cheap from ebay.
