jamiebridge Posted March 19, 2017 Share Posted March 19, 2017 So today i wrapped some spare steering wheel control covers. Got ready to install them, by removing the steering wheel and cant get the right anti tamper bolt out that holds the airbag in place. The thing just instantly sheered off (i am using the correct tool, t30 with anti tamper head). Has anyone experinced this? The left side came off fine. I have even tried to drill out the right side, but the metal seems to be so hardended it just wont go all the way through! Any ideas? Pic attached, you can see how far through i got with the drill (and also chewed some of the plastic surround in the process, which thankfully you cant see once the clip cover is back on). Any help much apprechiated. Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 19, 2017 Share Posted March 19, 2017 You almost want to force a regular socket over it and impact it off. Quote Link to comment Share on other sites More sharing options...
jamiebridge Posted March 20, 2017 Author Share Posted March 20, 2017 You almost want to force a regular socket over it and impact it off. I did think that, but the edges are completely smooth and rounded. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted March 20, 2017 Share Posted March 20, 2017 I had the same problem. Ended up using a 5mm metal drill bit and drill through until the top of the bolt separated. Once the wheel was off I could use pliers to turn what was left out of the hole Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 20, 2017 Share Posted March 20, 2017 Every bolt / screw can be removed by ramming a flat-head in there Quote Link to comment Share on other sites More sharing options...
KyleR Posted March 20, 2017 Share Posted March 20, 2017 Left handed drill bit? Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 20, 2017 Share Posted March 20, 2017 drill the head off, remove the shaft once the wheel is off Quote Link to comment Share on other sites More sharing options...
Richf Posted March 20, 2017 Share Posted March 20, 2017 Nissan are very generous with the loctite when fitting these bolts, you need a lot of torque to remove them and they are meant to be one use only but i reused mine ok Best bet is getting some decent drill bits as its likely stainless steel and you will ruin quite a few before that gives up Quote Link to comment Share on other sites More sharing options...
jamiebridge Posted March 20, 2017 Author Share Posted March 20, 2017 I had the same problem. Ended up using a 5mm metal drill bit and drill through until the top of the bolt separated. Once the wheel was off I could use pliers to turn what was left out of the hole Thanks for all the replies, I am going to give it a go with a 5mm like said above. Once these are out I will replace them with normal allen bolts, these t30 anti-tamper things are an unnecessary nightmare Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 20, 2017 Share Posted March 20, 2017 Absolutely agree. Same reason that locking wheel nuts are awful things. 1 Quote Link to comment Share on other sites More sharing options...
jamiebridge Posted April 6, 2017 Author Share Posted April 6, 2017 To help anyone in the future. I took it to a mate who works at a garage and has more tools than me, he managed to get a socket of some sort over it and eventually got it off, now both replaced with allen bolts. Quote Link to comment Share on other sites More sharing options...
