FatalRewind Posted March 14, 2017 Share Posted March 14, 2017 (edited) When I turn off the Z and open the door, the driver side window goes down too far. This leaves a gap when the window goes up a bit and door is closed. So far I've tried the window reset procedure multiple times with no joy. Both with and without the window motor reset button held. Also tried a new window motor and window switch. No change. Regulater looks ok. With the key turned and the door open I can put the window down then up as temp solution. Anyone know what could be causing this? Edited March 14, 2017 by FatalRewind Quote Link to comment Share on other sites More sharing options...
