ioneabee Posted March 13, 2017 Share Posted March 13, 2017 as the title - just curious and when / where would they / should they be utilised Quote Link to comment Share on other sites More sharing options...
Ekona Posted March 13, 2017 Share Posted March 13, 2017 Spoiler spoils airflow to reduce lift, wing adds downforce (in theory). Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 13, 2017 Share Posted March 13, 2017 probably wrong but - spoiler at the front down low, wing at the back up high, diffuser at the back down low Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 13, 2017 Share Posted March 13, 2017 (edited) probably wrong but - spoiler at the front down low, wing at the back up high, diffuser at the back down low Nope It's like Dan said, they go in the same place. Both reduce lift, but using different methods. Wings direct air upwards, pushing the car down, but causing drag. Spoilers prevent air from flowing where you don't want it, usually causing it to flow straight back, rather than downwards behind the car (causing lift), and reducing drag. Both are only functional at high speeds and improve cornering / stability. Spoiler top, wing bottom: Edited March 13, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
Mikevv Posted March 14, 2017 Share Posted March 14, 2017 That is all. I wonder if he can create diamonds with that much downforce Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 14, 2017 Share Posted March 14, 2017 Mikev, I raise you... Quote Link to comment Share on other sites More sharing options...
Mikevv Posted March 14, 2017 Share Posted March 14, 2017 I raise you again. He is literally driving a bunch of wing at this point surely??? 1 Quote Link to comment Share on other sites More sharing options...
AliveBoy Posted March 14, 2017 Share Posted March 14, 2017 Ok, I can't beat that They're both for pikes peak where the air gets so thin they need 10 millionty spoilers Quote Link to comment Share on other sites More sharing options...
Paul K Posted March 14, 2017 Share Posted March 14, 2017 I reckon it's just the extra weight of those wings keeping the car on the ground, not any fancy aero!! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 14, 2017 Share Posted March 14, 2017 Do you even wing.... Quote Link to comment Share on other sites More sharing options...
Aashenfox Posted March 14, 2017 Share Posted March 14, 2017 (edited) Although... That's a wing on a spoiler. P.S. there's another technical difference between a wing and a spoiler, a wing has air flowing over and under, a spoiler only over. Edited March 14, 2017 by Aashenfox Quote Link to comment Share on other sites More sharing options...
