Which Alternator belt for '07?
mammoth200
A little help required, and apologies as I'm sure this has been covered before, but I've yet to spot the answer I'm after.
The alternator belt I have just fitted is too long, the idler pulley adjuster is maxed out and the belt has 20mm odd deflection.
Now I've got a 6PK1175 fitted, and the interwebs tells me my trusty local motor factors have given me the wrong belt, but the old one was shot to pieces so needed replacing anyway. I'd like to fit something tighter as this currently lets out a little squeak on start up, which will get really old really fast.
So far I've found that everywhere lists the belt as being a 6PK1173, but is 2mm less really going to get rid of my enormous deflection? :teeth:
What's recommended? Thanks!
  • 3 weeks later...
  • 1 year later...
Dragging up this old thread from the depths (sorry folks).
I've just had to change the alternator belt after fitting one around a year ago, due to horrendous amounts of slack, noise, squeaking etc. I hadn't realised my Z had a pulley delete.
Question is now... What belt do I fit? A brand new standard belt causes the tensioner pulley to max out.
