Adrian@TORQEN Posted March 7, 2017 Share Posted March 7, 2017 (edited) Hi guys, New product exclusively available in Europe at TORQEN. These oil pumps will handle higher RPMS and create less cavitation. These will be based on upgrading a brand new OEM Oil Pump. The 350z pump is based on the RevUp OEM Oil Pump. Gear Details: * Hardness of gears is twice that of stock gears, and not brittle like other gears on the market * RPM Range: 8500 RPMs (With supporting internals of course), same gears running 8600 RPMs at 6bar of pressure in a road race build currently. * Billet Heat Treated Hardened 17-4 Stainless Steel * Moly Ceramic Dry Film Lubricant Coating * Tolerances within .0005" of the original gear. Back Plate Details: * Bolt on * 7075 Aluminum * Eliminates the flex Oil Pump Details * Helps Eliminate cavitation during higher RPMs. * Better flow with ~10% increase * Larger Volume of flow throughout the RPMs, stock held around 5" of vacuum, whereas after modifications, the pump held 20" of vacuum. Any questions, feel free to ask here. We're expecting stock Links 350z DE 350z HR 370z Edited March 7, 2017 by Adrian@TORQEN 1 Quote Link to comment Share on other sites More sharing options...
