Strudul Posted March 2, 2017 Share Posted March 2, 2017 (edited) Need some advice with prepping and painting aluminium. Not a Z body panel, but is to be installed on my Z. So far all I've done is give them a decent sanding, but the aly has a few deeper scratches. Tried doing some research online, but kinda got lost. Do I need to fill these or can I just use a primer? And then what sorta primer would I want (filler, etch, urethane, epoxy)? Can anyone with aly experience / knowledge explain the process and recommend some products (including paint etc)? Cheers Edited March 2, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
veilside z Posted March 2, 2017 Share Posted March 2, 2017 Acid etch primer any motor factor or Halfrauds. Key surface well then degrease. They do make filler primers depending on the depths concerned. 3 Quote Link to comment Share on other sites More sharing options...
ATTAK Z Posted March 2, 2017 Share Posted March 2, 2017 Even Aston Martin and Jaguar can't get it right, so I guess it's not easy Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 2, 2017 Author Share Posted March 2, 2017 Acid etch primer any motor factor or Halfrauds. Key surface well then degrease. They do make filler primers depending on the depths concerned. Nothing majorly deep, maybe 1mm. Not sure at what stage you can't get away with just primer... Quote Link to comment Share on other sites More sharing options...
Tricky-Ricky Posted March 3, 2017 Share Posted March 3, 2017 Once primed with an etch primer, you could use a filler/primer, but at 1mm those scratches are going to need a filler or stopper to loose them. 1 Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted March 3, 2017 Share Posted March 3, 2017 A decent High build filler primer over the etch should cope with 1mm. If you can find the smaller version of this https://www.globalfinish.com/featured-products-on-homepage/top-stop-gold-polyester-stopper-1-1l.html it's perfect for fine stuff over/after your filler primer. 1 Quote Link to comment Share on other sites More sharing options...
CLASSIX Posted March 3, 2017 Share Posted March 3, 2017 2 pac Kapcha primer 1 Quote Link to comment Share on other sites More sharing options...
Jetpilot Posted March 3, 2017 Share Posted March 3, 2017 Not so sure you and rattle cans are a good combination 2 Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 3, 2017 Author Share Posted March 3, 2017 (edited) Not so sure you and rattle cans are a good combination I'm amazing with my rattle cans as long as nobody has ambushed me with shoddy paintwork beforehand. However, there may be a chance to use a spray gun etc for this. Edited March 3, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
coldel Posted March 3, 2017 Share Posted March 3, 2017 TGM did the repair to my Celica bonnet (some builders dropped tiles on it!) which is all aluminium and they found it challenging, they are top top body work guys too. Hats off for giving it a go but its not easy by all accounts. 1 Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 3, 2017 Author Share Posted March 3, 2017 TGM did the repair to my Celica bonnet (some builders dropped tiles on it!) which is all aluminium and they found it challenging, they are top top body work guys too. Hats off for giving it a go but its not easy by all accounts. Which is the hard part, prepping, painting, or a combination of both? Was gonna say that I could do all the priming / filling / sanding myself and get it painted professionally, but surely once it's prepped, it's the same as painting anything else, you are painting onto primer, not aluminium. Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 3, 2017 Author Share Posted March 3, 2017 If it makes a difference, it's bare 1050 aly and there is no requirement for it to colour match anything else. Does need to withstand a slight curve / bow without the paint cracking though. Quote Link to comment Share on other sites More sharing options...
Strudul Posted March 3, 2017 Author Share Posted March 3, 2017 (edited) Just realised I was chatting bollocks with regards to the scratches, I think I was tired and just said a small number... The sheet aly is 1.2mm thick, so the imperfections must only be a fraction of a millimetre So I should be fine with etch, high build, then paint? Presumably followed by some lacquer? Edited March 3, 2017 by Strudul Quote Link to comment Share on other sites More sharing options...
