scotzman Posted February 28, 2017 Share Posted February 28, 2017 Hi All, Has anyone with a roadster or similar know how to route the reverse camera connections into the boot, ive taken the wires from the HU unit through the gear tunnel etc but cannot find a way into the boot, any help much appreciated. Thanks Quote Link to comment Share on other sites More sharing options...
hairyman68 Posted February 28, 2017 Share Posted February 28, 2017 Went wireless with mine..makes things a lot easier.. Quote Link to comment Share on other sites More sharing options...
Stutopia Posted February 28, 2017 Share Posted February 28, 2017 I've a coupe but pretty sure I fed my cam cable by opening up the glove box , removing the floor, feeding it into the space below there and then onward into the boot. It doesn't actually go into the glove box but you can access from there. Sadly I've no idea this is an unblocked route on a roadster. Good luck. Quote Link to comment Share on other sites More sharing options...
scotzman Posted February 28, 2017 Author Share Posted February 28, 2017 On 28/02/2017 at 16:55, SuperStu said: I've a coupe but pretty sure I fed my cam cable by opening up the glove box , removing the floor, feeding it into the space below there and then onward into the boot. It doesn't actually go into the glove box but you can access from there. Sadly I've no idea this is an unblocked route on a roadster. Good luck. Hi Stu, thanks for your reply, spent an hour with trim removed etc and cant still see a way through... its like trying to get in a fekkin safe... Quote Link to comment Share on other sites More sharing options...
scotzman Posted February 28, 2017 Author Share Posted February 28, 2017 On 28/02/2017 at 16:47, hairyman68 said: Went wireless with mine..makes things a lot easier.. Might have to go that way, is yours a roadster ? Quote Link to comment Share on other sites More sharing options...
hairyman68 Posted March 1, 2017 Share Posted March 1, 2017 Yes. Much easier that way.. Quote Link to comment Share on other sites More sharing options...
scotzman Posted March 1, 2017 Author Share Posted March 1, 2017 On 01/03/2017 at 08:32, hairyman68 said: Yes. Much easier that way.. Thank you sir, thats the way im gonna go, found the Receiver and Transmitter on fleabay... Quote Link to comment Share on other sites More sharing options...
