2nd guessing mechanic recommendation
Hi all =)
I need new pads an discs on my tree-fiddy HR, I'm guessing either a warped disc or dtv, with the pulsing and noise gradually getting worse.
After researching a bit on here and looking into products from companies such as Ferodo, Carbotech, Performance Friction, DBA, I spoke with my mechanic to see if he had any thoughts. He dismissed all of those as generic brands and recommend EBC discs and pads. Apparently he uses EBC on most of his vehicles, R34 skyline included, and thinks they're excellent, but I'm not comfortable with how he out of hand dismissed a swathe of brands that I know are recommended by others, and I've heard mixed reports regarding EBC.
I guess I'm looking for others thoughts and experiences relating to EBC, are they good, and recommendations if there is better available. I'm probably over thinking it, I'm just aware of a lot of brake companies including the likes of Pagid, Stoptech, etc, and wouldn't want to go on one person's say, when they ignored anything I had already looked into.
My 350z is my daily, but I would like to try some track days this year so I suppose I'm looking at something good from cold, but won't disappear in flames on a track.
Thanks in advance for your thoughts and opinions =D
Luke
I'm sure I remember reading that EBC were budget brakes and got rather mixed reviews, and generally recommended to get something better for track use.
He probably gets a good deal on EBC. Question is whether he is pocketing the extra profit or passing the savings on to you.
Edited by Strudul
Performance Friction are about as good as you can get, but are very expensive. I use stoptech discs and hawk pads and have been really impressed with them. Daily driving and a few track days and I'd definitely buy again. DBA are also supposed to be good. As Coldel stated, it sounds like your mechanic wants to sell you some EBC...
I'm waiting for suggestions and pricing from him regarding EBC, so don't know yet. I'd rather get the best I can afford than save a little, I'm a bit OCD. If I know that something in my price range is better, I will get that instead.
Sent from my SM-G935F using Tapatalk
Thanks all for the replies, you've kind of confirmed what I thought.
At the moment it's looking like DBA for the discs, unless anybody has a better suggestion for less money than the 4000 T3?
As far as pads go at the moment, I'm looking at CL, PF, and Project Mu. I have zero idea about what's good, or what's right for me; it's highly likely I'm going for a level of equipment I will never make good use of 😄
StopTech is the most popular brand we sell, they are extremely good discs brakes and always in stock.
slotted:
https://www.torqen.uk/nissan/350z/brakes/discs/495-350z-stoptech-direct-replacement-rotors-slotted-front-pair-with-brembo-calipers-12642076slr.html
https://www.torqen.uk/nissan/350z/brakes/discs/509-350z-stoptech-direct-replacement-rotors-slotted-rear-pair-with-brembo-calipers-12642079slr.html
slotted and drilled:
https://www.torqen.uk/nissan/350z/brakes/discs/501-350z-stoptech-direct-replacement-rotors-brembo-rear-pair-drilledslotted-12742079lr.html
https://www.torqen.uk/nissan/350z/brakes/discs/500-350z-stoptech-direct-replacement-rotors-brembo-front-pair-drilledslotted-12742076lr.html
drilled:
https://www.torqen.uk/nissan/350z/brakes/discs/506-350z-stoptech-direct-replacement-rotors-rear-pair-drilled-12842088lr.html
https://www.torqen.uk/nissan/350z/brakes/discs/502-350z-stoptech-direct-replacement-rotors-front-pair-drilled-12842080lr.html
Pads:
https://www.torqen.uk/nissan/350z/brakes/pads/491-350z-hawk-performance-ceramic-front-pads-brembo-hb545z564.html
https://www.torqen.uk/nissan/350z/brakes/pads/492-350z-hawk-performance-ceramic-rear-pads-brembo-hb180z560.html
or
https://www.torqen.uk/nissan/350z/brakes/pads/512-350z-stoptech-street-performance-brake-pads-front-brembo-30909600.html
https://www.torqen.uk/nissan/350z/brakes/pads/496-350z-stoptech-street-performance-brake-pads-rear-brembo-30909610.html
In case you haven't heard about StopTech yet have a look here:
http://www.stoptech.com/about/about-us
http://www.stoptech.com/racing/about-stoptech-racing
http://www.stoptech.com/products/rotors/stoptech-sport-rotors
Brake lines and fluid also in stock :)
Thx for the recommendation =)
If I would like track but it's also my daily, would you go for anything in particular?
and there is the rub, DBA are good discs but around twice the price of EBC, for road use EBC are fine for track use you will need a more aggressive pad also so buy a disc/pad combo you can afford to replace on a regular basis
EBC are perfectly fine for daily driving, I fitted their Yellow ones to my Megane RS250 and did a couple of track days on them as well, no issues what so ever. They used to have a bit of a bad rep with their old products but their current range is good.
Based on your requirements I'd say your mechanics recommendation is spot on from a price point.
Stoptech pads are pretty awesome. I threw some on in an emergency (I hadn't planned properly :rolleyes: ) and did a track day the next day, no bedding in at all and hammered the crepes out of them all day. Literally had no complaints at all, especially for the money and the fact they include new anti squeal shims too which is nice.
Thanks all for the information, I have a lot to consider!
As far as discs go, am I right in thinking that the drilling makes them more prone to cracking?
I would recommend DBA T2/T3 rotors, Carbotech pads, Goodridge lines and Motul RBF 600 fluid.
This, but I'd take Pagid RS29 pads and PF Floating discs if budget allows
Hehe, I think that sadly 2 piece rotors and Pagid pads are probably out of my price range :wacko:
Edited by Guest
RS29s are hardly everyday pads! lol not sure they're even road legal anyway. Hardcore track-use territory those...
I've driven on RS29's for must be 10 years and they are great from cold and handle all the track work you can throw at them, they aren't too aggressive to discs and out last most others too which goes a huge way to justifying their price tag in my opinion, don't even have bad manners in terms of noise either. The one and only down side I find is that the dust they produce does need to be cleaned off wheels fairly quickly and that's about it.
I think I'm right in saying proper Porsche's come with these fitted so as for legality I'm sure they are good too
