Roadster Window Not Auto Dropping Properly...
spike4real
Hi all,
I've noticed my passenger window is not dropping very much (maybe 2mm at most?) when opening the door. This causes the glass to catch and fold in the rubber seal which leads to a small leak when it rains. I've just ran through the reset procedure but it didn't make any difference. One thing I read after trying the reset is that the battery needs to be disconnected for 1-2mins before you do it - is this necessary? If so i might try it again while its dry. Failing that does it sound like a window motor issue?
Thanks
Dan
The reset procedure i followed was...
- Remove door card
- Close the window fully (not using auto-close)
- Close the door (or keep door sensor pressed)
- Press & hold the motor reset button
- Open the window fully (not using auto-open)
- Release motor reset button
- Open the door (or let go of door sensor)
- Reinstall door card.
