SamJ Posted February 26, 2017 Share Posted February 26, 2017 So I've spent some time this evening trawling the forums for a similar case but couldn't find one so a thread it is. Basically when I shut the drivers side door it makes a sort of rattle/bang as if the window is loose, I'm assuming that the window pane is loose or something but just wondering if anyone else has had this? Just wanna ask before I start stripping trim and panels back haha. Il try get a video in the morning Thanks all Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Strudul Posted February 26, 2017 Share Posted February 26, 2017 Mine does that, but only with the window down... Quote Link to comment Share on other sites More sharing options...
Keyser Posted February 26, 2017 Share Posted February 26, 2017 if it does it when the window is up, check the auto drop is working - as in the window drops a few mm when you open the door and goes back up all the way when shut, if not do the reset procedure Quote Link to comment Share on other sites More sharing options...
