Stuttering from low rev pull in 2nd
SwissZ
Hi
When I'm in 2nd gear with low revs, leaving a roundabout for example, the car's not pulling smoothly and kind of stutters/bogs down a little. Seems to get worse once it's warmed up.
Did a quick search and saw a few threads about this on 313 350s, but nothing for 370s.
It's done just over 30,000, has recently had an Invidia fitted, but was doing it before that was fitted.
Any ideas?
Cheers
Is it the same as the HR hesitation issue? Mine used to kind of 'cough' for a second before going if I planted my foot, regardless of which gear I was in. Sometimes it was actually quite a violent loss of power. If you have an early 370, I believe you would have the same engine with the same issue.
