goughy Posted February 19, 2017 Share Posted February 19, 2017 afternoon, Help..... can anyone tell me if the supply to the drivers door switch is fed by the window switches in the drivers door? i have no power to the door switch, i have tested everything and all the passenger side workings are fine, and the drivers side has no window drop and no interior light, worst is the fact if you unlock the car and don't get as far as turning the ignition on and it re locks, any help would be great as i don't want to do a full strip and trace of the single wire. cheers Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 19, 2017 Share Posted February 19, 2017 Sounds like it may be a BCM issue. All parts to fix your issue are in stock and good to go same/next day including a fully working BCM. Good luck with your diagnosis. Just drop me a PM if I can help further. Alex. 1 Quote Link to comment Share on other sites More sharing options...
goughy Posted February 19, 2017 Author Share Posted February 19, 2017 (edited) Sounds like it may be a BCM issue. All parts to fix your issue are in stock and good to go same/next day including a fully working BCM. Good luck with your diagnosis. Just drop me a PM if I can help further. Alex. hi Alex thanks for the reply, what sort of cost is the replacement bcm as bays about 50 delivered and does it need coding once replaced ian Edited February 19, 2017 by goughy Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 19, 2017 Share Posted February 19, 2017 Ian, Drop me a PM with the year and model of your car please. Alex. Quote Link to comment Share on other sites More sharing options...
