Transmission specialist near Warwick?
350Butcher
Not sure this is the right section but......
I've put my diff back together with new bearing etc and I am after a transmission expert/specialist near Warwick if anyone can recommend someone/somewhere?
They need to be properly up on measuring bearing preloads in in-lbs and checking clearances and kitted out to reshim if necessary.
Cheers
It's the bearing pre load I really want checked on the new pinion I've installed and I don't have the gear for? This is a specialist job as it needs to be set to a very tight and strict tolerance.
The shims and the rest I can do really but would leave to someone else to double check if I found someone good.
Did you know of anyone?
