Finchy Posted February 18, 2017 Share Posted February 18, 2017 Hi everyone I took delivery of my 19" rota grids last night and before I rush down the garage and fit them do I need different wheel bolts or spigot ring ect? I could really do with not loosing a wheel if I'm honest... I thought the rings were just to keep the wheel central when fitting and what not.. any help would be much appreciated Cheers jack Quote Link to comment Share on other sites More sharing options...
KyleR Posted February 18, 2017 Share Posted February 18, 2017 Should have spigots, you're oem bolts are the correct taper, but pretty fat, so you will probably find it a tight squeeze to get the 19mm bit in, most use 17mm nuts. I think the spigots should be ID 66.1, can't remember OD, 73 maybe? Quote Link to comment Share on other sites More sharing options...
