Porsche Cayman 987 3.4
galgazza
I'm fairly confident Dan's first words will be about getting an inspection, but other than that it'll be positive, especially as it's a manual, apparently without PASM. It's on 19s not 18s though, so he'll have something to hold back on ;)
:lol:
Seems to be about the right price for its age, marzman has certainly given me some doubts..
Just read this post from Adrian who bought one a few years ago...
http://www.350z-uk.com/topic/97666-temporary-toy-for-the-summer-porsche-cayman-s/
They share the same weaknesses as the 996 911 which i had one of. Bore scoring, D-Chunk issues, IMS failure - all resulting in an £8k rebuild required. I read one stat on a 911 forum that probably 25% of cars are effected by these issues.
Thanks for the link marzman to all the troubles Adrian had. It has put me off to a degree but surely they can't all suffer the same issues.
Every old car is a gamble but I guess the possible lossses on this is a major concern. I will have to check what the 6 month warranty covers.
On a review on autocar it says "A tiny minority of Gen 1 S 3.4s suffered bore scoring, caused by liners being to thin and inefficient cooling of cylinders five and six"
Every used car is a risk and not sure if I should let it put me off.
Dan would also say that the rate of fails has become a bit of an internet hobby horse, somewhat overstating the actual rate of fail.
There's a really well informed piece by a specialist on this very subject out on the web, let me have a search.
Edit - I think this is the one http://www.porscheinspections.com/qanda.php or this one http://www.porscheinspections.com/content/downloads/M96_M97_GTPorsche.pdf
PS - Where is Dan? Is he ok? Not slipped getting out the bath?
I'd hasten to add that Adrian also ignored every word of advice put forward by Dan before buying his. Just something to consider when Dan does find this thread.
Of course, the most practical way to protect yourself from these issues it to get an inspection done on any potential car beforehand... but at £200-300 and a ball ache to organise, its too much of a PITA if you ask me. But then without one you'll always be wondering and listening out for every single little noise! Thats what I did, and its not fun.
Edited by marzman
HAI GUISE
It would appear that my work has been done for me :D The actual link isn't opening for me right now so I'll be General with my comments but in short:
1. Inspection, inspection, inspection. Even if you don't cough up for a specialist inspection at about £300, for god sake at least get a local garage to do a boroscope inspection. If there's serious bore scoring, walk away. Minor marks are nothing to be worried about though.
2. If you're running 19"s, you'll want PASM unless you hate your spine. These cars are superb on standard suspension amid 18" wheels, much better than with the PASM and any wheel combo. Note this is for gen1 only, gen2 PASM is superb.
3. Assuming the bores are fine, the only other thing that will get you is the IMS going pop. Nowt you can do about this really, you could split the gearbox and engine then replace with new OR remove the internal dust shield which then allows the engine oil to lubricate the IMS bearing rather than it chewing itself to pieces. Either option should give you as good as peace of mind as you can get, and is what I would do should I buy an M96/97 engined car. Labour won't be cheap, if you can time it with a clutch change more the better!
4. Gen1 PCM 2.1 (sat nav) is f*cking dire. Don't worry if the car hadn't got it, you won't miss it! Gen1 Bose also gash, like it is on the 350. Neither applies to the gen2, where they're both excellent.
5. Risk of the engine exploding is about 5-10%. If it goes you're looking at a bill of about £3k-£8k, depending on how much you rebuild. Don't worry too much, but don't go in blind. This is why point number 1 is so important!
6. Enjoy the best sports coupe sensible money can buy. The Cayman is more than just numbers, it's about a pinsharp chassis and a delicate steering rack and a gloriously gutsy engine.
That'll do. Always open for a PM discussion if you want. :)
  • Like 2
