where to plug a mechanical gauge to check engine oil pressure>350z<
valy
  On 17/02/2017 at 18:10, ZMANALEX said:
There is also an independent ancillary take off in the same area as the oil pressure sender unit, however as what IMC has said, swopping out the sender for the independent gauge is my preferred option.
Do you not need the stock pressure sensor fitted alex? I thought the variable timing would run off it like a Honda. Not really sure how it works on the vq though
  On 18/02/2017 at 10:53, Jez @ H-Dev said:
We use a sandwich plate and oil pressure gauge on a braided line.
my local garage didn't have one but we took out the pressure sending unit and connected the mechanical gauge and it showed us just under 40psi while with the sending unit on was just at 5 psi... :)
