Ukeraa Posted February 13, 2017 Share Posted February 13, 2017 Annoyingly my sub seems to pop and barely work. I've looked it up and it seems quite common, but I'm an absolute layman and don't want to do anything without a professional. How much would be acceptable to fix? I'm based in the Southend area. I'll check tomorrow if it's a loose wire, but I have a feeling it could be more than that. Any experience with fixing the sub then please feel free to post. Quote Link to comment Share on other sites More sharing options...
Strudul Posted February 13, 2017 Share Posted February 13, 2017 Got the same issue and never managed to resolve it. Best bet is replacing the sub amp. Or use it as an excuse for a new sound system. Quote Link to comment Share on other sites More sharing options...
ph 7 Posted February 14, 2017 Share Posted February 14, 2017 it is really easy. The guide is here: http://www.350z-uk.com/topic/85821-how-to-bose-subwoofer-cutout-fix-amp/ Honestly, 4 bolts to remove the sub, 2 bolts to loosen the amp, unclip the amp, buy the relay, ask a friendly electrician to solder the relay onto the board. Job done. I previously did the folded card solution, but it is really temporary. Quote Link to comment Share on other sites More sharing options...
Strudul Posted February 14, 2017 Share Posted February 14, 2017 Relay replacement didn't work for me. Never fixed the pops and only temporarily stopped the cutting out. Quote Link to comment Share on other sites More sharing options...
Ukeraa Posted February 16, 2017 Author Share Posted February 16, 2017 Changed the relay and it worked! Took longer than expected but I'm pleased. The proper test will be tomorrow on an hour and a half drive, but so far it's sounding perfect . 1 Quote Link to comment Share on other sites More sharing options...
