Cazgraeme Posted February 13, 2017 Share Posted February 13, 2017 I filled with fuel paid got back in car. Car dead. Door locks are working but dash says no key. Tried using 2nd key but got same result. Anyone got any suggestions. Quote Link to comment Share on other sites More sharing options...
Renegade Posted February 13, 2017 Share Posted February 13, 2017 (edited) Try putting the key fob into the key port. Its at the side of the steering wheel. From the manual. INTELLIGENT KEY BATTERY DISCHARGE If the low battery indicator 5 appears in the vehicle information display, replace the battery as soon as possible. If the battery in the Intelligent Key is almost discharged, the guide light 6 of the Intelligent Key port blinks and the key insertion indicator 7 will appear in the vehicle information display. To start the engine under these circumstances, insert the Intelligent Key into the key port with the key ring end toward you until it latches into place. Then push the ignition switch to start the engine. To remove the Intelligent Key from the port, push the ignition switch to turn the engine off and then pull the Intelligent Key out of the port. Do not insert the mechanical key or any other objects into the Intelligent Key port. Inserting any object other than the Intelligent Key will damage the Intelligent Key port. Edited February 13, 2017 by Renegade Quote Link to comment Share on other sites More sharing options...
MITZ@CougarStore Posted February 13, 2017 Share Posted February 13, 2017 Steering lock failure, possibly? Quote Link to comment Share on other sites More sharing options...
Renegade Posted February 14, 2017 Share Posted February 14, 2017 I was thinking that too. Were the cars called back to fix that ? Quote Link to comment Share on other sites More sharing options...
Richf Posted February 14, 2017 Share Posted February 14, 2017 I was thinking that too. Were the cars called back to fix that ? nope , Quote Link to comment Share on other sites More sharing options...
Ebized Posted February 14, 2017 Share Posted February 14, 2017 I was thinking that too. Were the cars called back to fix that ? Thread here: http://www.350z-uk.c...-recall-action/ Page down to latest outcomes, if your issue turns out to be the same - good luck! Quote Link to comment Share on other sites More sharing options...
Cazgraeme Posted February 14, 2017 Author Share Posted February 14, 2017 Many thanks everyone. Still waiting to hear from the garage. 1 week still no sign of my baby coming home. Will post the prognosis. Quote Link to comment Share on other sites More sharing options...
Cazgraeme Posted February 23, 2017 Author Share Posted February 23, 2017 Got my baby back today. No more astray courtesy car. Yippee!!! Apparently it was the key reader on the steering column. Many thanks for the replies Quote Link to comment Share on other sites More sharing options...
