Ricksta1980 Posted February 12, 2017 Share Posted February 12, 2017 Does anyone have a link for the install ? I have 1 wire I'm not sure about lol would like to fit this asap Quote Link to comment Share on other sites More sharing options...
marzman Posted February 12, 2017 Share Posted February 12, 2017 http://www.350z-uk.com/topic/105649-installation-guide-350z-de-d1-spec-gt-throttle-controller/ 1 Quote Link to comment Share on other sites More sharing options...
Ricksta1980 Posted February 12, 2017 Author Share Posted February 12, 2017 Thanks for that, very helpful. On the box that you plug the 2 white clips/wires into there is also a small red wire with a female connection, I don't know what this is for or what plugs into it, any ideas ? Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted February 13, 2017 Share Posted February 13, 2017 Thanks for that, very helpful. On the box that you plug the 2 white clips/wires into there is also a small red wire with a female connection, I don't know what this is for or what plugs into it, any ideas ? Think that was for the reverse sensor, didn't bother fitting that one. Works fine without it Quote Link to comment Share on other sites More sharing options...
Ricksta1980 Posted February 14, 2017 Author Share Posted February 14, 2017 Thanks mate, didn't want to fit it not knowing. Cheers Quote Link to comment Share on other sites More sharing options...
Ricksta1980 Posted February 18, 2017 Author Share Posted February 18, 2017 All installed and set up as per instructions, as soon as I put my key into ignition I'm getting a high pitched noise that doesn't stop, even if I start the engine, until key is removed. Any advise ? Quote Link to comment Share on other sites More sharing options...
MikeyM Posted February 18, 2017 Share Posted February 18, 2017 All installed and set up as per instructions, as soon as I put my key into ignition I'm getting a high pitched noise that doesn't stop, even if I start the engine, until key is removed. Any advise ? Not heard of that happening.. If it was me I would simply unplug it from loom..put loom back to normal..start engine, see if noise gone. Then plug controler back into loom and see if it comes back ..of not, great, if it does, logic says fault with controler 🤔 Quote Link to comment Share on other sites More sharing options...
Ricksta1980 Posted February 18, 2017 Author Share Posted February 18, 2017 I've sorted it now, it went when I closed the drivers door and never happened again, strange lol Quote Link to comment Share on other sites More sharing options...
MikeyM Posted February 18, 2017 Share Posted February 18, 2017 I've sorted it now, it went when I closed the drivers door and never happened again, strange lol I'm saying nothing lol Quote Link to comment Share on other sites More sharing options...
