Front suspension arm bush failing..?
hairyman68
Did the car fail or was it an advisory? If it was advised, do you get any knocking or steering wheel wobble? If you don't and your tyre wear is even, I'd leave it, all you're being told is the rubber bush is starting to perish but no excess movement. Unless its affecting the way it drives.
