Mikeyazure Posted February 8, 2017 Share Posted February 8, 2017 Hi All, is there such a thing? I can usually find most things but this one is hiding from me Quote Link to comment Share on other sites More sharing options...
GreenLandy Posted February 10, 2017 Share Posted February 10, 2017 Do you need one?? Wheel off, caliper off, release/slacken off handbrake shoes (through the rubber plug in the disc there's a cog to turn) and then pull the thing off (might be a screw holding it on, can't quite remember) 1 Quote Link to comment Share on other sites More sharing options...
Mikeyazure Posted February 10, 2017 Author Share Posted February 10, 2017 haha and there was me thinking it was more complicated than the fronts.,... thank you ... Quote Link to comment Share on other sites More sharing options...
Paddy78 Posted February 10, 2017 Share Posted February 10, 2017 I've changed mine before... which means anyone can! The only problem you will run into is if you leave your handbrake on (or in gear). As you are lifting the rear wheels make sure the fronts are chocked so your car can't roll away! Quote Link to comment Share on other sites More sharing options...
Mikeyazure Posted February 10, 2017 Author Share Posted February 10, 2017 well thank you...im going to use a four post lift here......www.thisisyourgarage.com because of the weather and because i can play at being a grease monkey Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted February 10, 2017 Share Posted February 10, 2017 Search youtube... Quote Link to comment Share on other sites More sharing options...
Mikeyazure Posted February 10, 2017 Author Share Posted February 10, 2017 thanks Rob Quote Link to comment Share on other sites More sharing options...
