BenC Posted January 28, 2017 Share Posted January 28, 2017 Hi All, Just a quick one. I have an 04 Nissan Fairlady Z JDM with circa 75k miles. I believe that I have lost a piston ring, bottom end bearing or similar (guess is bottom end). I am interested in either: 1. Rebuilding the engine 2. Fitting a recon engine I am based in the SE of London and so far have looked at Abbey Motorsport and Dartford Rebore and Engine Centre, but not had any estimates. If any one is interested in recommending places or providing estimates for a rebuild or recon refit please do let me know. Thanks, B Quote Link to comment Share on other sites More sharing options...
greasyphil Posted January 28, 2017 Share Posted January 28, 2017 can we ask how the engine got damaged? i think the readers of this forum would like to know, we constantly listen to are engines for any unusual noise 1 Quote Link to comment Share on other sites More sharing options...
BenC Posted January 29, 2017 Author Share Posted January 29, 2017 Sure thing. Been burning through oil quite heavily, say a litre for 1200 miles for the last 5000 miles. Started noticing a performance drop in throttle response and shortly (within 100 miles) after I heard a large rattle that I assume is the piston in the bore. Rattle goes in sync with revs. Driven less than 500 yards after making the heavy engine rattle. 1 Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted January 31, 2017 Share Posted January 31, 2017 What was the oil level like when it popped ? Quote Link to comment Share on other sites More sharing options...
veilside z Posted January 31, 2017 Share Posted January 31, 2017 Expect around paying anything upwards from £1500 - £2500 for a decent engine swop buddy. Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 31, 2017 Share Posted January 31, 2017 I have this engine available 46000 miles with service history and can be seen / heard running http://www.350z-uk.com/topic/113702-350z-de-engine-gearbox-diff-etc-46000-miles/ Quote Link to comment Share on other sites More sharing options...
BenC Posted January 31, 2017 Author Share Posted January 31, 2017 Veilside - yes oil level was lowish as light came on under heavy cornering P15UL T - Will keep this in mind. Where abouts are you? Quote Link to comment Share on other sites More sharing options...
Willsy1980 Posted January 31, 2017 Share Posted January 31, 2017 I think the light is low oil pressure as opposed to low oil level. If you see the light it's usually game over, as you have found out. Probably spun the rod/main/crank bearings at a guess, if it's knocking with the revs it's most likely the rod bearings. Some can be done from the bottom with the engine in. But if the shrapnel has been pumped round, or is visible in the oil when drained then a full build or replace is the only way. Feel for you either way Quote Link to comment Share on other sites More sharing options...
veilside z Posted January 31, 2017 Share Posted January 31, 2017 So so many have gone this way recently Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 31, 2017 Share Posted January 31, 2017 Veilside - yes oil level was lowish as light came on under heavy cornering P15UL T - Will keep this in mind. Where abouts are you? I'm just west of Glasgow Quote Link to comment Share on other sites More sharing options...
BenC Posted February 15, 2017 Author Share Posted February 15, 2017 Thanks all, still struggling to find a garage who will do a rebuild/engine swap. I am expecting to pay circa 2k but happy to sell the car for around the same as is. Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted February 15, 2017 Share Posted February 15, 2017 Abbey will do a build or a swop for you. Best to give them a ring to discuss. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted February 15, 2017 Share Posted February 15, 2017 Does it still run or totally kaput ? If it runs, can you confirm where the noise is coming from, using either a loooong screw driver or a mechanics stethoscope. Everyone automatically assumes the worst but sometimes it's not ! If you're unsure, take it to Kaizer or Abbey. For example - read this and look what people assumed first: http://www.350z-uk.com/topic/101584-bad-engine-noise-any-ideas/ And check out what Sly at Kaizer did It might still be burning some oil but they do anyway, and yeah maybe new rings in the future. 1 Quote Link to comment Share on other sites More sharing options...
Sinnistar Posted February 17, 2017 Share Posted February 17, 2017 BenC,hope it's nothing big...I had an issue but in oil and smoke from my engine bay. I was mortified, but looking through the engine bay I noticed the dip stick was not seated all the way in...I little bit of the rubber seal was torn...ordered a new one from Z1 Motorsports and no issues since. I hope your issue is something simple. On a side note Kaizer And Abbey are both 4 hours south of me, can anyone recommend a shop near Leeds ? BCk on the subject of BenC...clogged pcv valve stuck closed ? That's a possibility and really cheap to fix/change your self. Quote Link to comment Share on other sites More sharing options...
Sinnistar Posted February 24, 2017 Share Posted February 24, 2017 Any updates ? Quote Link to comment Share on other sites More sharing options...
Ricksta1980 Posted February 26, 2017 Share Posted February 26, 2017 Don't use dartford rebore, they ****ed my engine ! They paid for a new one but still grief Quote Link to comment Share on other sites More sharing options...
huseyin Posted March 1, 2017 Share Posted March 1, 2017 Looks like my engines got the same issue mine also cuts out after a min or two . Keep us updated of the 'fix' or a new engine . Quote Link to comment Share on other sites More sharing options...
