iLott Posted January 28, 2017 Share Posted January 28, 2017 (edited) Any know how to remove the air filter from the Vortech V3?! Can't for the life of me figure it out, there is no room to manoeuvre it out! Cheers Dan Edited January 28, 2017 by iLott Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 28, 2017 Share Posted January 28, 2017 With torn knuckles ! Not the easiest job Quote Link to comment Share on other sites More sharing options...
iLott Posted January 28, 2017 Author Share Posted January 28, 2017 Which way does it come out?! From the top of the bottom?? Bottom doesn't look like enough room and top I can't get it out without practically folding it up!! Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
d95gas Posted January 28, 2017 Share Posted January 28, 2017 The following came from the Yank forums, dont know if it helps: lossen lug nuts jack car up remove lugs remove wheel with a 10mm socket, remove the bolts from the lower heat shield that tie into the front fender liner ( i think 3) with a flat head, pop the 3 plastic clips holding the fender liner in remove fender liner remove filte Quote Link to comment Share on other sites More sharing options...
evilscorp Posted January 28, 2017 Share Posted January 28, 2017 Most people crush it to remove it from the top. Quote Link to comment Share on other sites More sharing options...
jumping350 Posted January 28, 2017 Share Posted January 28, 2017 Most people crush it to remove it from the top. +1 Quote Link to comment Share on other sites More sharing options...
evilscorp Posted January 28, 2017 Share Posted January 28, 2017 a quick goolge and you get images like this put a small twist and then compress, not ideal but if you are cleaning it then re using it, probably the easiest way to do it. Quote Link to comment Share on other sites More sharing options...
iLott Posted January 28, 2017 Author Share Posted January 28, 2017 Yeah I did crush it and remove it, seems a bit ridiculous that this is the way to remove it, or spend an hour taking other bits off just to get to it. Oh well it's done now thanks for the help! Sent from my iPhone using Tapatalk 1 Quote Link to comment Share on other sites More sharing options...
P15UL T Posted January 29, 2017 Share Posted January 29, 2017 I've fitted a large k&n cone filter above my intercooler and temporarily connected it with flexible aluminium piping. I will be getting something more permanent fabricated but for now it works a dream and keeps the filter away from the engine bay Paul Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 29, 2017 Share Posted January 29, 2017 I've fitted a large k&n cone filter above my intercooler and temporarily connected it with flexible aluminium piping. I will be getting something more permanent fabricated but for now it works a dream and keeps the filter away from the engine bay Paul Did you see Sam Mcgoo's guide on doing that Paul? Link: http://www.350z-uk.c...air-intake-cai/ It's where I got the idea to do it on mine when I had it. Such a better place for the filter plus you can actually use quite a big filter. Quote Link to comment Share on other sites More sharing options...
nissanman312 Posted January 29, 2017 Share Posted January 29, 2017 My stillen set up is like this now aswell I need to look into getting the filter out the way Quote Link to comment Share on other sites More sharing options...
jumping350 Posted January 29, 2017 Share Posted January 29, 2017 Go on then pic time heres my attempt Quote Link to comment Share on other sites More sharing options...
GMballistic Posted January 29, 2017 Share Posted January 29, 2017 ^^ I still have no idea what magic you use to get the Zed in & out of that garage. Quote Link to comment Share on other sites More sharing options...
evilscorp Posted January 29, 2017 Share Posted January 29, 2017 Quote Link to comment Share on other sites More sharing options...
iLott Posted January 30, 2017 Author Share Posted January 30, 2017 Good idea. I've cleaned mine 5 times now and still getting as much dirt out each time as I did on the first attempt. Even with the bubbles of oxy stain removed mixed with carbonated water still doesn't manage to clean it right out. So time for a new one I think. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
jumping350 Posted January 30, 2017 Share Posted January 30, 2017 ^^ I still have no idea what magic you use to get the Zed in & out of that garage. Thankfully I dont have to now its in my friends double garage sooo much easier to get in it now I haven't seen it for 3 months now though so really miss it! Evilscorp that intercooler is mahoosive Move it out front ilott you will get an element of heatsoak where it is now im sure, so out front at least its away from all of that 1 Quote Link to comment Share on other sites More sharing options...
ChrisB Posted January 30, 2017 Share Posted January 30, 2017 Here you go chaps. Just did mine.. not too many dramas.. http://www.350z-uk.c...80#entry1698896 FWIW, not sure that the removal of the wheel arch trim instructions work on RHD cars - it looks to me like the metalwork and A/C pipes still get in the way.. I could be wrong as I didn't bother trying wheel arch trim route and did it from the top, but.. looks crowded to me Quote Link to comment Share on other sites More sharing options...
