2 year owner.. trying to get into using the forum! Need some help and advice!
Alright everyone! Michael here, got a 2004 chilli red 350z. Love it to bits!! Got a hit and run by some chick a while back and only got it all foxed up off the insurance recently and it loooks brand new!! Got a few little fixes to do though, the coolant fan doesn't cut in and in traffic she can overheat.. so I never go out if there is a danger of sitting motionless for a period of time. Any ideas or common faults which lead to this? Reckon I should try to do the coolant temp sensor first as they go for a fiver on ebay! Also My gearbox sometimes gives a wee grind into 6th, been reading a lot of people say about changing the oil and adding molyslip? Anyone reckon this would remedy this fault? The engine and box have done just over 60k miles.
Thanks guys!! Any help appreciated!
Much love,
Mikey Beefsmash!
Traders on here can sort out what you need, for Oil there are Opie Oils and and I believe Zmanalex who I have bought Nissan oil from before. If you are doing the gearbox oil always worth adding a bit of molyslip as well, Zed gearboxes are notoriously clunky and molyslip will help alleviate some of the clunkyness.
Shift gate is a good idea too, takes ten mins easy to do.
Thanks for all the replies and welcomes guys! Much appreciated!
What should I do with the shift gate??
Click the linky I gave you...
Ah thanks very much!! Will give that a bash! Hopefully all that will get her sorted! The gearbox oil change do-able jacked up?
:welcome: Along
Good luck with the issues, gearboxes do go but oil and moly may give you an extended stay on that, 5th usually goes first though then 3rd.
Plenty of info on the forum though - fans do stick, there is a "how to" for cleaning them or try Zmanalex for a pre-owned set failing that after market options are available :thumbs:
  • Like 2
