martinh55 Posted January 22, 2017 Share Posted January 22, 2017 I'm just changing my spark plugs. Had a search about and read Through a few guilds on here. No body seems to mention a torque setting for the new plugs. I found on 350z tech that is bitween 15 and 21ft-pounds. Does this sound right? Also I'm fitting ngk laser platinum spark plugs so I assume they are pre gapped already? Thanks for the help in advanced because in balls deep in the engine bay! Haha Quote Link to comment Share on other sites More sharing options...
d95gas Posted January 22, 2017 Share Posted January 22, 2017 (edited) Download the Torque details HERE, these are direct from my Autodata interface so should be correct. Also attached Technical specification _ Autodata.pdf Edited January 22, 2017 by d95gas Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 22, 2017 Share Posted January 22, 2017 25nm, which is approximately hand tight plus a tweak Quote Link to comment Share on other sites More sharing options...
davey_83 Posted January 22, 2017 Share Posted January 22, 2017 On the spark plug box, it'll state how much to tighten them up by ie fully hand tight then 3/4 turn. Quote Link to comment Share on other sites More sharing options...
martinh55 Posted January 22, 2017 Author Share Posted January 22, 2017 Thanks for the heads up. Just matched as close as possible how tight the old plugs where. Took the car out for a spin and it fires up fine and drives fine. I didn't over or under tighten the plugs. I noticed some think about turns on the box. But was so blind as I was looking for a torque figure. That torque sheet d95gas is perfect I will be printing that off and saving it to my phone and laptop. Nice one. Quote Link to comment Share on other sites More sharing options...
mr v6 Posted January 26, 2017 Share Posted January 26, 2017 What are the manufacturers part numbers for these plugs (Iridium, NGK etc)? The standard ones on the Z are the same as my old 406 Coupe, the PLFR5A-11 (6240). I keep reading up about the Denso Iridium ones though. Any part numbers will be appreciated. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted January 26, 2017 Share Posted January 26, 2017 Use opie oils if you're unsure, or make an order through one of the traders. Quote Link to comment Share on other sites More sharing options...
martinh55 Posted January 26, 2017 Author Share Posted January 26, 2017 (edited) What are the manufacturers part numbers for these plugs (Iridium, NGK etc)? The standard ones on the Z are the same as my old 406 Coupe, the PLFR5A-11 (6240). I keep reading up about the Denso Iridium ones though. Any part numbers will be appreciated. just dug a box out of the recycling bin you had me worried then Same part number PLFR5A-11 6240 Edited January 26, 2017 by martinh55 Quote Link to comment Share on other sites More sharing options...
KyleR Posted January 27, 2017 Share Posted January 27, 2017 What are the manufacturers part numbers for these plugs (Iridium, NGK etc)? The standard ones on the Z are the same as my old 406 Coupe, the PLFR5A-11 (6240). I keep reading up about the Denso Iridium ones though. Any part numbers will be appreciated. Just get the PLFR5A-11 you mentioned. They're good for 50k easily and most Zeds would have their plugs changed before that anyway. Iridium will last 75k or so, but has a weaker spark than Platinum and hold no advantage other than longevity that I am aware of. Quote Link to comment Share on other sites More sharing options...
RobPhoboS Posted January 27, 2017 Share Posted January 27, 2017 I just got LFR5A-11 (6376) - standard, cheap copper core ones as I'd rather check up on them annually. Quote Link to comment Share on other sites More sharing options...
Auckies Posted February 19, 2017 Share Posted February 19, 2017 Spark plugs, a quick job I thought! Nissan must of had a competition to see how fiddly they could make it. I work on aircraft and they have their moments but plugs on my Z'd where a challenge. Quote Link to comment Share on other sites More sharing options...
VQ35UK Posted May 26, 2017 Share Posted May 26, 2017 My spark plugs haven't been changed since new (05), I'm expecting them to be seized, so was planning on buying an impact wrench to get them out. Are they too fiddly to use an impact gun? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 26, 2017 Share Posted May 26, 2017 Do not use an impact gun on your spark plugs under any circumstances: 1 Quote Link to comment Share on other sites More sharing options...
Jay84 Posted May 26, 2017 Share Posted May 26, 2017 They're rubbush on a crashqai too, you have to remove the inlet before you can see the coils. Quote Link to comment Share on other sites More sharing options...
VQ35UK Posted May 27, 2017 Share Posted May 27, 2017 Do not use an impact gun on your spark plugs under any circumstances: Not for putting new ones in obviously, but for taking them out, an impact gun is less likely to shear anything, or am I missing something? Quote Link to comment Share on other sites More sharing options...
ZMANALEX Posted May 27, 2017 Share Posted May 27, 2017 Do not use an impact gun on your spark plugs under any circumstances: or am I missing something? Yes possibly a few brain cells. Do not go near your spark plugs with an impact gun to remove or refit. 3 Quote Link to comment Share on other sites More sharing options...
Science_GT Posted June 26, 2017 Share Posted June 26, 2017 The plugs on mine when I changed them were all loose! God knows what idiot fitted them before and didn't help a coil pack going. Quote Link to comment Share on other sites More sharing options...
