Are DE and HR rear coil springs the same
Bob94
Maybe a stupid question but does anyone know if they are the same? I assume they are as they all say 2003-2009 but I need to get a single Spring but no point if it's not right.
I think it's best practice to replace both, as you would with dampers, brake discs and pads etc.
Usually I would agree 100% but I've found a rear Spring for £14 which would do me over till after I've got my welding done then I'm getting some tein springs just can't afford both and the welding is my highest priority atm
As above always change springs / shocks in pairs - AFAIK the springs will fit DE to HR but you should change the pair as mileage and driving style will make a difference to the spring recoil and strength.
DE and HR springs are the same.
Plenty in stock and good to go same/next day.
£12.00 each or £20.00 for a pair.
Just drop me a PM if I can help further. :thumbs:
Thanks I'll drop you a pm when I find out if it's just one or both that have gone
