Neil Posted January 20, 2017 Share Posted January 20, 2017 Hi, I have purchased a 370z 2016 plate. I cannot download my iPhone 6 phone book to the car and therefore cannot see any caller display. When I select 'download phonebook' the bluetooth connection drops. I then select 'OK' and the bluetooth connection restores. Has anyone managed to download their phonebook to the car and if 'yes', can you tell me how to do it please? Nissan technical have said 'that's how it is on the 370z' which I find hard to believe. Thanks in advance. Neil Quote Link to comment Share on other sites More sharing options...
Renegade Posted January 20, 2017 Share Posted January 20, 2017 Try This https://www.nissanus...e-compatibility To connect your Apple iPhone 6 through Bluetooth, your vehicle must be stationary. STEP #1: PREPARE YOUR PHONE Turn Bluetooth on: Name your phone: From the Main Screen, Select "Settings" Select "Bluetooth" Slide toggle switch to "On" or "Off" Device names cannot be changed in phone menu These steps are currently not available. STEP #2: PREPARE YOUR VEHICLE Press the "Phone" button Select "Connect Bluetooth" Select "Yes" STEP #3: PAIR YOUR PHONE TO THE VEHICLE From the Main Screen, Select "Settings" Select "Bluetooth" Select "[MY-CAR]" Verify the passkey shown on the vehicle and the phone are the same If so, accept pairing request on the phone STEP #4: VEHICLE CONFIRMATION Select "Yes" STEP #5: SETTING UP YOUR DEVICE AS AN AUDIO PLAYER Select "Connected Devices". You may need to wait until the system finishes downloading your phonebook. Select "Audio Player" Select your connceted device from the list Choose "Select" from menu STEP #6: ADDING YOUR CONTACTS TO THE VEHICLE PHONEBOOK Each paired phone has its own dedicated phonebook. Two phonebook setup options are available depending on your phone's support for Phonebook Access. Option 1: Phones which support Phonebook Access: When a phone is connected to the system, the phonebook is automatically downloaded to the vehicle. No additional setup is required to begin voice-dialing contacts by name. To transfer the handset phone book manually: Press the "Setting" button Select "Phone" Select "Download Handset Phonebook" Option 2: Phones which DO NOT support Phonebook Access: Up to 40 entries can be added to the vehicle phonebook. You may enter contacts downloaded from the Handset or use the Keypad or Call History. Option 1: Adding Contacts Via Bluetooth (depends on phone compatibility): On your vehicle: On your phone: On your vehicle: Press the "Phone" button Select "Vehicle Phonebook" Select "Add New" Select "Copy from the Handset" Select "Voicetag" to record a name for the Voice Recognition system Select "Store" Say the name of the contact after the tone Select "OK" to save the entry Option 2: Adding Contacts Via Keypad: On your vehicle: Press the "Phone" button Select "Vehicle Phonebook" Select "Add New" Select "Enter Number by Keypad" Enter contact number Select "OK" Select "Voicetag" to record a name for the Voice Recognition system Select "Store" Say the name of the contact after the tone Select "OK" to save the entry Option 3: Adding Contacts Via Call History (depends on phone compatibility): On your vehicle: Press the "Phone" button Select "Vehicle Phonebook" Select "Add New" Select "Copy from Call History" Select the number to save in the vehicle phonebook Select "OK" Select "Voicetag" to record a name for the Voice Recognition system Select "Store" Say the name of the contact after the tone Select "OK" to save the entry Quote Link to comment Share on other sites More sharing options...
Neil Posted January 20, 2017 Author Share Posted January 20, 2017 Hi Renegade, Thanks for this, but I know I am connecting correctly. My problem is that when I select the 'download phone book' option, Bluetooth disconnects. When I hit the 'OK' button to continue, Bluetooth reconnects. Nissan are suggesting it is a iPhone issue but I have tried several phones (friends) and the issue remains. I guess that as no one seems to have an issue, it must be the car system, but I need to convince Nissan of this... Thanks Neil Quote Link to comment Share on other sites More sharing options...
Renegade Posted January 20, 2017 Share Posted January 20, 2017 In the hand book it says :- Wireless LAN (Wi-Fi) and the Bluetooth􀂊 functions share the same frequency band (2.4 GHz). Using the Bluetooth􀂊 and the wireless LAN functions at the same time may slow down or disconnect the communication and cause undesired noise. It is recommended that you turn off the wireless LAN (Wi-Fi) when using the Bluetooth􀂊 functions Try turning your phones wifi off, if it is on as an experiment. Quote Link to comment Share on other sites More sharing options...
Neil Posted January 20, 2017 Author Share Posted January 20, 2017 Thanks again, Renegade, I actually said out loud 'that makes perfect sense' when I read your post so I ran to the car with great anticipation. Unfortunately it did not work The message 'add to handset memory' message appears and I click 'OK'. At this point the bluetooth drops - can't work it out. I'll keep on it though. Thanks again. Neil Quote Link to comment Share on other sites More sharing options...
Renegade Posted January 20, 2017 Share Posted January 20, 2017 Are you sure it says add to handset memory ? as that to me looks as though the car wants to write to the phone memory. If that's even possible. If you go to settings, then phone. Is auto download turned on ? that is for the phone address book. I never use mine it was 2015 when I set it up. I have just been to the car and my phone just connected. Though it is an old Samsung S2. Quote Link to comment Share on other sites More sharing options...
Neil Posted January 21, 2017 Author Share Posted January 21, 2017 HI Renegade, When I select 'download phone book' I see image attached. If I select 'yes', the Bluetooth connection drops and I see the second message. I do not see any prompt on the phone to add a passkey so I select 'done'. Bluetooth connection is restored. If I select 'No' to the 'Add to handset memory message' nothing happens. I am convinced there is a fault with the Media System but need to prove this so that Nissan take notice. Thank you for help. Neil Quote Link to comment Share on other sites More sharing options...
