Help! Calling 370z 2016 Owners re: Phone Book
Neil
Hi,
I have purchased a 370z 2016 plate.
I cannot download my iPhone 6 phone book to the car and therefore cannot see any caller display.
When I select 'download phonebook' the bluetooth connection drops. I then select 'OK' and the bluetooth connection restores.
Has anyone managed to download their phonebook to the car and if 'yes', can you tell me how to do it please?
Nissan technical have said 'that's how it is on the 370z' which I find hard to believe.
Thanks in advance.
Neil
Try This https://www.nissanus...e-compatibility
To connect your Apple iPhone 6 through Bluetooth, your vehicle must be stationary.
STEP #1: PREPARE YOUR PHONE
Turn Bluetooth on:
Name your phone:
  1. From the Main Screen, Select "Settings"
  2. Select "Bluetooth"
  3. Slide toggle switch to "On" or "Off"
  4. Device names cannot be changed in phone menu
These steps are currently not available.
STEP #2: PREPARE YOUR VEHICLE
  1. Press the "Phone" button
  2. Select "Connect Bluetooth"
  3. Select "Yes"
STEP #3: PAIR YOUR PHONE TO THE VEHICLE
  3. Select "[MY-CAR]"
  4. Verify the passkey shown on the vehicle and the phone are the same If so, accept pairing request on the phone
STEP #4: VEHICLE CONFIRMATION
  1. Select "Yes"
STEP #5: SETTING UP YOUR DEVICE AS AN AUDIO PLAYER
Select "Connected Devices". You may need to wait until the system finishes downloading your phonebook.
  1. Select "Audio Player"
  2. Select your connceted device from the list
  3. Choose "Select" from menu
STEP #6: ADDING YOUR CONTACTS TO THE VEHICLE PHONEBOOK
Each paired phone has its own dedicated phonebook. Two phonebook setup options are available depending on your phone's support for Phonebook Access.
Option 1: Phones which support Phonebook Access:
When a phone is connected to the system, the phonebook is automatically downloaded to the vehicle. No additional setup is required to begin voice-dialing contacts by name.
To transfer the handset phone book manually:
  1. Press the "Setting" button
  2. Select "Phone"
  3. Select "Download Handset Phonebook"
Option 2: Phones which DO NOT support Phonebook Access:
Up to 40 entries can be added to the vehicle phonebook. You may enter contacts downloaded from the Handset or use the Keypad or Call History.
Option 1: Adding Contacts Via Bluetooth (depends on phone compatibility):
On your vehicle:
On your phone:
On your vehicle:
  2. Select "Vehicle Phonebook"
  3. Select "Add New"
  4. Select "Copy from the Handset"
  5. Select "Voicetag" to record a name for the Voice Recognition system
  6. Select "Store"
  7. Say the name of the contact after the tone
  8. Select "OK" to save the entry
Option 2: Adding Contacts Via Keypad:
On your vehicle:
  3. Select "Add New"
  4. Select "Enter Number by Keypad"
  5. Enter contact number
  6. Select "OK"
  7. Select "Voicetag" to record a name for the Voice Recognition system
  8. Select "Store"
  9. Say the name of the contact after the tone
  10. Select "OK" to save the entry
Option 3: Adding Contacts Via Call History (depends on phone compatibility):
On your vehicle:
  3. Select "Add New"
  4. Select "Copy from Call History"
  5. Select the number to save in the vehicle phonebook
  6. Select "OK"
  8. Select "Store"
Hi Renegade,
Thanks for this, but I know I am connecting correctly. My problem is that when I select the 'download phone book' option, Bluetooth disconnects. When I hit the 'OK' button to continue, Bluetooth reconnects.
Nissan are suggesting it is a iPhone issue but I have tried several phones (friends) and the issue remains.
I guess that as no one seems to have an issue, it must be the car system, but I need to convince Nissan of this...
Thanks
Neil
In the hand book it says :-
Wireless LAN (Wi-Fi) and the Bluetooth􀂊
functions share the same frequency band (2.4
GHz). Using the Bluetooth􀂊 and the wireless
LAN functions at the same time may slow down
or disconnect the communication and cause
undesired noise. It is recommended that you
turn off the wireless LAN (Wi-Fi) when using the
Bluetooth􀂊 functions
Try turning your phones wifi off, if it is on as an experiment. :)
Thanks again, Renegade,
I actually said out loud 'that makes perfect sense' when I read your post so I ran to the car with great anticipation. Unfortunately it did not work :(
The message 'add to handset memory' message appears and I click 'OK'. At this point the bluetooth drops - can't work it out.
I'll keep on it though.
Thanks again.
Neil
Are you sure it says add to handset memory ? as that to me looks as though the car wants to write to the phone memory. If that's even possible.
If you go to settings, then phone. Is auto download turned on ? that is for the phone address book.
I never use mine it was 2015 when I set it up.
I have just been to the car and my phone just connected. Though it is an old Samsung S2.
HI Renegade,
When I select 'download phone book' I see image attached. If I select 'yes', the Bluetooth connection drops and I see the second message. I do not see any prompt on the phone to add a passkey so I select 'done'. Bluetooth connection is restored.
If I select 'No' to the 'Add to handset memory message' nothing happens.
I am convinced there is a fault with the Media System but need to prove this so that Nissan take notice.
Thank you for help.
Neil
