W Brace replacement -Which one to go for?
Stephanie
Hi Guys,
Had the Zed in the garage yesterday and was able to take a quick look underneath, immediately obvious the "W" brace needs replacing, it could probably last a while longer, maybe even a wire brush and hammerite jobby at a push (see attached photo of current brace)
..but I've had a quick search on eBay and you can pick up a brand new Ultra racing brace for £139 delivered, the Zeds booked in the garage in a couple weeks anyway and will be on ramps so will be easy/cheap enough labour wise to take off the old and bolt on the new -well that's what I thought...
Done some reading and spoken to ZMANALEX and the UR braces stick out more than OEM, which could prove a problem.. she's sat on tein lowering springs so is pretty low, but is she too low for a UR brace? Don't want every speed bump being a PITA.
Anybody have a UR brace with a low Zed?
Trying to show the clearance in the above photos - not the easiest to take, not the best shots 😬 Side skirts do make her look lower than she is also☺ï¸
Any experience/advice of the braces will be greatly appreciated.
Edited by Stephanie
I ran the Summit braces on my old one (the UR ones are a copy of their design), and even though my car wasn't lowered it did scrape a bit. Not a lot, but enough to take the paint off it.
Personally I'd just brush over and paint your existing.
  • Like 2
Hmmm decision time🤔
Thankyou for all suggestions/advice -much appreciated.
Perhaps this is one thing that doesn't need splashing on. More in the pocket for other partsðŸ‘ðŸ¼
Edited by Stephanie
Removed mine last year and cleaned as much of the surface rust off as possible, gave it 2 coats of Bilt Hambers Hydrate 80 which I must say is fantastic stuff and then 2 coats of smoothrite on top.
Refitted using copper grease on all the bolts, also while doing an engine & gearbox oil change gave all the bolts holding any covers underneath the same treatment.
Just a note on the Hydrate 80, I gave a rusty old antique wheel that I had from my old farmer mate a couple of coats of it at the same time, it stands out in all weathers and the surface rust that it had changed to black looks like I painted it yesterday, didn't put any top coat paint on that by the way.
  • Like 3
Safe? Yeah. Good idea? Nope. It'll make the car wobbly as anything, as essentially it's doing a very important job of connecting the two sides of the car together, so you'd find extra wear on suspension components and a hell of a lot of scuttle shake. The chassis would be trying to twist itself every corner.
It may look a bit naff and flimsy, but you'd be surprised at just effective things like that are from an engineering POV.
Noted, ill get hunting for a new one then :)
  • 1 year later...
  • 3 years later...
