HKS vs Nissan oil filter
davey_83
It's approaching that time again, do I go with the Japanese £20, French £10 or British £5 filter? Or does it not make a difference either way, but I'm not looking to lower the oil pressure.
Cheers
David
Hexhead filters ftw.
Otherwise I usually get a Mann filter or OEM. Alternatively I'll simply pick the biggest one that'll fit, as more filtering capacity is really what you're after. IIRC the Subaru ones are usually a good size, or the Vauxhall ones.
I've got the Greddy magnetic sump plug - it's bloody strong! Can be a bit tricky getting it back into the sump as it just wants to a stick to everything :lol:
Other than that I just use a Mann oil filter. Never had a problem getting the filter off by hand - "Iron Grip" :teeth:
Happy to be shot down here but why bother with magnetic sump plugs? :surrender:
My reasoning being that really high end engines, Ferrari, Porsche, buggati, none of them see the need for putting a magnet on the sump out of the factory. Adding a £20 magnet on exotic engines would hardly be difficult to justify if there were any benefits.
My guess is there are no benefits hence why every manufacturer is not putting them on. :p
Because for 20 quid it could potentially save anymore damage being done. It did on my old Honda when the oil pump let go, caught a lovely nugget.
Got a mishimoto (spelling) on mine and im pretty sure it got the same pull pound for pound as the moon. Relatively small sumps on zeds make for catching any nastys quite easy
Because a lot of our cars are roughly 10yrs+ old and over the years tolerances change. From new when everything is still perfect I agree there's probably not much benefit as the running in process is there to help.
I see both points however I am still not convinced. With all the R&D and tech that car manufactures put into engines, if they felt there was "any" benefit to adding a magnet they would have I am sure.
Sorry for being a cynic :surrender:
Manufacturers use them for gearboxes and differentials, I guess car makers leave the collecting of the swaft for replaceable oil filters.
It's like oil catch cans, we all know the benefits but they're not standard fit on performance cars.
Edited by davey_83
